I saw this in an advertisement that I recently got via email (https://www.toolsource.com/extractor...Toolsource.com). It looks like it could be a great tool for those having difficulties with removing door screws.
Wivco TH28000 Shake-N-Break(TM) Air Impact Screw Remover
Air impact screw & fastener removal tool that uses standard, changeable, 5/16" hex insert bits that fit any or all fasteners & screws used today.
It is used in conjunction w/ a standard air hammer, w/ safety spring, at low air pressures.
The tool will loosen rusted, corroded, undercoated, painted, dirty, & overly tightened screws fast & efficiently.
Vibration shakes the screw loose while you simply turn the screw w/ the attached handle.
This simple, high quality tool finds its greatest use on cars, trucks, motorcycles, boats, & farm equipment.
It loosens stuck fasteners in places like wheel openings, headlight doors, taillight lens, bumpers, striker pins, seatbelt bolts, floor pans, motorcycle engines, & thousands of other places.
I like using the impact type tool. Especially when you're working away hammering on it and you get the web between your thumb and forefinger on the hammering surface
Pretty good idea. I have the Vessel Impact Driver and it works most of the time. I also have a drill chuck type adapter for my 1/2" impact that works well. I like this air chisel idea.
I made one of these yesterday, took less than 10 minutes after I found all the parts. I am pretty impressed with it. Managed to loosen the hinge screws on my M3 which I’m sure I would have had to drill out. They were really stuck. I had to turn up the air pressure on the gun to really blast them. Definitely recommend one. Whether you buy one or make it yourself. I tried to upload a video , but I don’t know how. , Doug.
I just ordered this one from Amazon for $15.22 with Prime. They also have one in 1/2" drive, may order that one too. I already have 3/8 drive impact sockets so no worries.
