Charging issues
Old Apr 12, 2019 | 07:53 AM
  #31
knottyrope's Avatar
knottyrope
ground strap could do it but you engine wont crank over if there isn't one connected
Have you cleaned your grounds to engine?
Did you jump the exciter and get any output?
Old Apr 12, 2019 | 09:36 AM
  #32
BuddyBarnes's Avatar
BuddyBarnes
Originally Posted by pstrokemike97
Could a bad ground strap or 2 cause this, also wondering if i should try and get my money back from napa and get a motorcraft alternator, have a feeling im getting duds from napa
Any parts house should be able to spin that alternator up and see if it is putting out the required voltage, NAPA included. If it is,the alternator is not the problem.
Old Apr 12, 2019 | 01:23 PM
  #33
pstrokemike97's Avatar
pstrokemike97
im still a bit confused on where to run it, am i going from the positve terminal on battery to the small plug on the alternator, or to the pigtail that plugs into that same plug?
Old Apr 15, 2019 | 08:32 AM
  #34
knottyrope's Avatar
knottyrope
Either one. We need to make sure 12v goes to it and then check output of ALT
Tritonstables
Jan 21, 2018 04:45 PM
Scoob5555
Nov 4, 2012 04:59 PM
thehawk75
Oct 26, 2008 10:03 PM
Schuebo
Oct 17, 2007 06:30 AM
yardboy
Nov 29, 2005 10:13 PM
