Charging issues
Old Apr 10, 2019 | 09:00 AM
pstrokemike97's Avatar
pstrokemike97
Originally Posted by knottyrope
GP shorts out and draws high amps and welds the contacts of GPR and then over works the charging system
I think your alt is bad by the test you did. Volts is not going up when you have 12 on exciter.
Your GPR is bad from welded contacts.
Unplug the GP that's burt out. It can run fine with a few GPs out. Just smoky and rough till it warms up.
You need GPR, get a stancor one
new GPs only get ZD11 motor craft ones
UVCH can get oem pieces or upgrade to SD ones which can carry more current with out burning out.
just put in brand new motorcraft glowplugs when i did the valve cover harnesses 2 weeks ago... will they still be good or did the shorted out gpr most likely smoke my brand new glow plugs
Old Apr 10, 2019 | 10:44 AM
knottyrope's Avatar
knottyrope
you will need to ohm each GP out with wires removed to see if still good. No way to know for sure with out testing them.
GPs can run a while and most have built in protection from over heating but you never know
Old Apr 10, 2019 | 01:19 PM
Hussler's Avatar
Hussler
Probably both. Here is a picture of the big disk inside the GPR. The disk is suppose to rotate on each cycle but sometimes it doesn't. You can see where it was arching and if bad enough it becomes an arc welder? The disk slams against the two large posts inside the relay making contact from the always hot power side to the glow plugs side..
Originally Posted by pstrokemike97
This was my connector after it fried. Id think this could have something to do with my gpr shorting out, or my gpr is the cause for this to short out��
Old Apr 10, 2019 | 06:27 PM
pstrokemike97
Well went to napa and swapped out my alternator and put the new one on and it is still not charging, only reading 2-3 volts out of post when running. Batteries are reading 11.58 volts, pigtail is reading the same. Once again back to square 1. Gpr is disconnected as well
Old Apr 11, 2019 | 08:50 AM
knottyrope's Avatar
knottyrope
Only 3 volts with everything connected to alt?
Old Apr 11, 2019 | 09:13 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Or three volts on the exciter wire?
Old Apr 11, 2019 | 11:26 AM
pstrokemike97
12v coming out of the threaded post on back when connected, when i unbolted the wire and tested running there was only 2-3v max coming out of the post.
Old Apr 11, 2019 | 11:37 AM
knottyrope's Avatar
knottyrope
Alt isn't doing its job for some reason
Possible the alt isn't grounded any more
Did you clean off the corrosion where the alt bolts to engine?
Old Apr 11, 2019 | 11:49 AM
pstrokemike97
no it looked pretty clean but i will sand it down alon with contact points later tonight
Old Apr 11, 2019 | 02:09 PM
knottyrope's Avatar
knottyrope
One other thing to try is run a wire from + side of battery to the exciter on the Alt but please put an inline 10 amp fuse. This will bypass the gauge, light etc and prove the alt is working. Then test output while running engine and GP is off.
I am thinking that you did see 12v on the exciter plug but once connected, there isn't enough current to excite the alt
Old Apr 11, 2019 | 03:42 PM
pstrokemike97
ok will try that, wouldnt a 10 amp fuse instantly blow when connected, i think the alt is 130 amp
Old Apr 11, 2019 | 03:50 PM
knottyrope's Avatar
knottyrope
the wire and fuse is for the exciter circuit aka small wire that we want to bypass for the test
You could jump from big post on Alt to the exciter instead of from battery but I would still fuse it
Old Apr 11, 2019 | 04:32 PM
  #28
farmert's Avatar
farmert
Does the alternator light work in the dash? If I'm not mistaken, the light is part of the circuit. (ground? or maybe the exciter circut) If the light is burned out the alternator will not charge.
Old Apr 11, 2019 | 05:09 PM
  #29
pstrokemike97
light is on in dash
Old Apr 11, 2019 | 09:19 PM
  #30
pstrokemike97
Could a bad ground strap or 2 cause this, also wondering if i should try and get my money back from napa and get a motorcraft alternator, have a feeling im getting duds from napa
