7.3 IDI knock
Old Apr 6, 2019 | 06:43 AM
daltrod's Avatar
daltrod
7.3 IDI knock
I have a 1993 F450 7.3 IDI with a knock I'm trying to diagnose. If I crack the fuel line to the inner passenger side cylinder it goes away. Once you tighten it back up it come back loud and clear. The engine runs smooth normally but when I crack the fuel line the injector stops working and the engine clearly begins to shake. All the searching online has me guessing between injector and bearing/wrist pin. I've never done this work before so I'd have to pay for this but don't want to just start guessing at a fix, instead of wasting money on tshooting a possible injector i'd rather put the money to a replacement motor. It stands to reason that if the cylinder is not firing then it's not under pressure so the bearing/wrist pin is quite but at the same time I would think that if it's indeed mechanical as I rev it up with the fuel line cracked open I would still hear a knock just from high RPMs on those parts. Any ideas or suggestions would be greatly appreciated!!
Old Apr 6, 2019 | 11:28 AM
DarkOverCast's Avatar
DarkOverCast
You can get one injector for $40 and change it out with a cresent wrench. That would be the cheapest way forward. If that doesn't fix it then you can start looking for a replacement engine
Old Apr 7, 2019 | 07:17 AM
tjc transport's Avatar
tjc transport
i ain't rite
i agree. swap in a different injector.
Old Apr 7, 2019 | 01:24 PM
Macrobb's Avatar
Macrobb
More than likely injector.
Fella
Sep 22, 2017 09:46 AM
jdb111485
Aug 3, 2010 11:48 AM
powerstroked162
Jan 14, 2009 10:03 PM
geaux tigers
Dec 4, 2006 10:53 PM
