rod knock?
Old Apr 5, 2019 | 05:45 PM
williams242's Avatar
williams242
rod knock?
i have a 73 f250 with a 360 in it. i recently did the rear main seal along with new oil pump (stock flow). I got the truck a couple weeks ago have not really drove it due to the fact when i got it the exhaust was rusted out.. so im not sure when i ran it before i did the work to it if it had a knocking in the motor due to the exhaust being so loud. i did all the work and put some new exhaust on it and now that i can hear the motor sure sounds like a rod knock to me. from what i can tell with out digging to far into it sounds like its passenger side. sounds like its in the front cylinders also sounds like its kind of a high knock by the head maybe. just looking for a little clarification if that is a rod knock or something else. was try to see what a stock style engine rebuilt would cost. i appreciate any help thanks
Old Apr 5, 2019 | 06:05 PM
caravaggio2000's Avatar
caravaggio2000
The first thing I'd check is if you have loose exhaust bolts on your manifold or headers.
Old Apr 5, 2019 | 06:26 PM
williams242
I also replaced all the bolts and new manifold gaskets along with the donut gaskets for the down pipes off the manifold
Old Apr 5, 2019 | 06:28 PM
caravaggio2000
You might be right, but I'd recheck for an exhaust leak and loose exhaust bolts. FE's are notorious for them.
Old Apr 5, 2019 | 07:02 PM
williams242
Definitely not an exhaust leak like I said before yesterday I just relplaced all the manifold bolts and brand new gasket and donuts for the down pipes
Old Apr 5, 2019 | 10:03 PM
niko20's Avatar
niko20
Grab a mechanic's stethoscope from Harbor Freight and use it to pin down where the sound is coming from.
My experience with rod knock is it gets louder as you let off the gas. Like, rev up, then let off, then the knock gets louder...
But it may be hard to tell if it's just detonating or rod knock
Old Apr 6, 2019 | 09:49 AM
Ozzie H.'s Avatar
Ozzie H.
I agree. try to do a good diagnosis before disassembly.
Old Apr 6, 2019 | 03:18 PM
mark a.'s Avatar
mark a.
Pull the spark plug wire from the suspected cylinder. If it's a bad rod it will quit knocking.
Old Apr 6, 2019 | 09:34 PM
PA74F250's Avatar
PA74F250
Probably a wrist pin knock not a rod. It’ll sound similar but will last longer than a rod knock.
Old Apr 7, 2019 | 02:59 AM
matthewq4b's Avatar
matthewq4b
If you can post a video and then we will be able to give you a more positive diagnosis.
williams242
Aug 8, 2019 05:59 PM
williams242
28
Apr 8, 2019 10:20 AM
tbruz
23
Mar 4, 2019 07:47 PM
WALJON
16
Dec 25, 2009 06:56 PM
1974f250
Jan 14, 2009 04:58 PM
