6.0l small squeak on cold start
I've got a 2004 f250 with a 6.0l, and 164k miles on it. Thing runs great, but on a cold start, usually 10 seconds or so later, I'll hear a squeak from the engine, just one squeak, then it stops ,never been able to figure where it was coming from.
I say squeak, but maybe whine would better describe it.
In any case, where could I begin to diagnose this noise?
Was driving the truck today. It would work fine, but then or would start lacking power on the freeway.
Was only building 1-2 psi of boost cruising where 8-9 was typical, and the vgt duty cycle was at 85% while cruising.
Also, the egts were about 1k cruising at 75.
Going to pull and clean the turbo in the morning. Figure to check and clean the EBP sensor and MAP port while I'm there.
on
P1000 means the PCM software has not experienced all the different operating conditions to test if everything is working correctly and make adjustments for optimal driving. When it has completed all of them, the code turns off.
If there is a out of normal conditions event, the check engine light will turn on.
08F550
1999 to 2016 Super Duty
04-06-2014 01:12 AM
96ford4x4turbodiesel
04-12-2004 08:46 PM
