Bouncing Speedometer
Old Apr 3, 2019 | 12:28 PM
Capt'n Jack's Avatar
Capt'n Jack
So with this inherited truck, I get to fix the problems that my dad just dealt with. This one wasn't much of a problem for him because he lived in the city and didn't get much over 45 mph, ever. A bunch of years ago when he bought it, it had 35" tires on it. He was out playing in the mountains and shredded a rear tire. He was only a few miles from home so he just put the regular size spare on and limped home. After that, the speedometer will function smoothly up to about 40-45 mph then it starts to bounce. Over about 65 it's completely useless bouncing all over the place. He replaced the speed sensor in the rear end thinking he messed that up with the different size tires, no help there. Also the cruise doesn't work, I assume it gets it's signal from the speedometer. Am I looking at needing a different instrument cluster, or is this a sensor issue?
Edit: I guess my signature doesn't show up yet.
1994 F150 4X4 5 spd 5.0L
Extended Cab Short Bed
Old Apr 3, 2019 | 05:33 PM
Conanski's Avatar
Conanski
It's either a PSOM or wiring problem between it and the rear axle, the PSOM attaches to the back of the speedo module. The speed signal goes through the PSOM before going to the PCM and cruise control.
Old Apr 3, 2019 | 06:24 PM
TexasGuy001's Avatar
TexasGuy001
On one of my previous trucks the speedometer needle wouldn't stop bouncing unless the RABS behind the glove box was disconnected. It had a new Ford VSS and no other issue could be found. The thinking was the the voltage was too low when shared between the two.
Old Apr 4, 2019 | 07:25 PM
PRIMERED79 SHORT BED's Avatar
Mine did the same thing some years back, ended up being three chipped teeth on the tone ring in the diff.
mikedepalma
Feb 18, 2016 10:54 AM
jim33067
Aerostar
Jan 29, 2014 09:01 PM
doublebutted
May 11, 2012 04:51 PM
Ilovebroncos
1978 - 1996 Big Bronco
Feb 27, 2007 10:42 AM
BOB6867
Feb 15, 2004 07:52 PM
