1986 f150 302 problems
Old Apr 3, 2019 | 05:31 PM
vjsimone's Avatar
vjsimone
Originally Posted by Fordfarmer79
Thank you, that's a big help. I was looking in the FAQs for that, but must have skipped over that...
You can briefly ground the two injector wires going to the ECA to see if the bank of injectors fire.
Old Apr 3, 2019 | 05:47 PM
vjsimone's Avatar
vjsimone
the truck begins to stall
When you turn the key to ON, do you get the 1-2 Fuel Pump Prime ?
You should run your KOEO Self-Test, see what your computer knows.
Pull out your ACT and check the tip on the sensor.
Old Apr 3, 2019 | 06:15 PM
Fordfarmer79's Avatar
Fordfarmer79
Act? Guess you will have to use full names till I get it all figured out.
Old Apr 3, 2019 | 07:06 PM
matthewq4b's Avatar
matthewq4b
Air Charge Temperature sensor. There is no MAF (mass air flow sensor) in these trucks as they use speed density to calculate air flow in to the engine.
Old Apr 3, 2019 | 07:20 PM
diggerrigger's Avatar
diggerrigger
ACT is located in lower manifold under left bank fuel rail. The white plug in the center of the photo.
Old Apr 3, 2019 | 07:40 PM
vjsimone's Avatar
vjsimone
They are on the schematic on post #14.......
Old Apr 3, 2019 | 07:52 PM
vjsimone's Avatar
vjsimone
Fuel Injection Technical Library » Air Charge Temperature (ACT)
Old Apr 3, 2019 | 08:59 PM
Fordfarmer79
Awesome, thank you again.
Old Apr 4, 2019 | 05:41 PM
Fordfarmer79
More on the truck, it is getting good power to the injectors. I temporary run a ground while someone else cranked, and it wanted to spit and sputter. I was going to look at the computer wiring, but ran out of time. I noticed there are two computer looking boxes down there. I assume it's the one that has the larger bolt in connector?
Old Apr 4, 2019 | 06:12 PM
vjsimone's Avatar
vjsimone
Old Apr 4, 2019 | 06:39 PM
Fordfarmer79
That's it. Thanks, guess Google would work for that ....
Old Apr 5, 2019 | 11:55 AM
Fordfarmer79
Just a thought, I have an 86 Mercury grand Marquis. Would that computer work for a test?
Old Apr 5, 2019 | 12:24 PM
  #28
vjsimone's Avatar
vjsimone
No.
Did you pull your computer and check the capacitors ?
If you put a test light or meter on one of the injector connectors, you should be able to tell if the computer is firing them.
Have you run the KOER Self-Test ?
Old Apr 5, 2019 | 12:35 PM
  #29
Fordfarmer79
It's not going to hurt anything.
The automobile EFI was ahead of the Truck, so you might get a few codes that you would not with your truck computer.
Have not run any tests yet. I'm 99% sure the injectors are not firing on at least one side because the truck doesn't even try to start unless I ground them out temporary arcing it across the battery neg.
Old Apr 5, 2019 | 12:38 PM
  #30
vjsimone's Avatar
vjsimone
Unplug your TPS connector and try to start.
(Throttle Position Sensor)
