Steering column
Old Apr 2, 2019 | 07:42 PM
dogsgunstrucks's Avatar
dogsgunstrucks
Steering column
I am looking for a steering column to install in my 1968 f100. I want a column from a 1978-79 F series truck with power steering,tilt and automatic. Can't seem to find one. So my question is this. Is a Bronco column the same? Different years? Thanks for any help Terry
Old Apr 2, 2019 | 11:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by dogsgunstrucks
I am looking for a steering column to install in my 1968 F100. I want a column from a 1978-79 F series truck with power steering, tilt and automatic.
Tilt steering column (only the wheel tilts) introduced in 1978 F100/350, Bronco & Econoline with A/T & 4 speed, not available with 3 M/T in F100/250 & Econoline.
Bronco tilt column 4WD related, will not work with 2WD
Old Apr 3, 2019 | 01:50 PM
dogsgunstrucks
Thanks Numbers Dummy.What is the difference between the two columns? Can the bronco column be modified to fit?
Old Apr 3, 2019 | 02:23 PM
NumberDummy
Thanks NumberDummy. What is the difference between the two columns?
Probably not.
Bronco & 4WD's have a lower steering shaft and coupler assy (3B676 in pic) that connects the upper steering shaft (3524) to the input shaft of the steering gearbox using a rag joint (3A525).
2WD's have a one piece steering shaft w/a flange on the end. The rag joint bolts to the flange, then connects to the input shaft of the steering gearbox.
Pic: 1978/79 Bronco (and F150 4WD) Tilt Column with A/T
Rusty_Old_F250
Jan 19, 2015 01:29 PM
lisagoud
Ford Truck Parts for Sale
Apr 25, 2014 03:53 PM
rwrogers
Jan 29, 2014 06:58 PM
daningraham
Mar 8, 2013 08:56 AM
cwpitman
Mar 3, 2005 02:16 PM
