Will a tilt column from a 2wd 78/79 with power steering work in a 2wd 73 with manual steering?
Also, do the 78/79 and the 77- earlier steering wheel's use the same spline count and diameter?
Sam
No, the manual steering column is a few inches longer than the power steering column.
On the spline count and diameter, I think they're the same but not a 100% sure.
I'm pretty sure the splines on the end of the shaft is the same, the manual steering column is longer, I can't remember since I usually work on 4x4s, is there a shaft between the sector and column or just a flex coupler? If there is a shaft it can possibly be shortened
Thanks guys, I've thought about converting to power, but, I like my manual steering, keeps me in shape. And I just had the box rebuilt, not in a hurry to spend $300 again....
The column was at the junkyard, if the price is right I'll grab it anyway, I think I can modify it to work. That extra room would be a good spot for a telescoping section and a u-joint.
Tilt column (only the wheel tilts) introduced in 1978 F100/350, Bronco & Econoline (A/T only). Available with A/T & 4 M/T (very hard to find). Not available with 3 M/T
3 different 1978/79 T/S switches used with the above: (1) With tilt wheel (A/T & 4 M/T); (2) with A/T only; (3) with 3 or 4 M/T only.
1978/79 F100/350's use different rag joints than 1973/77* F100/350. Tilt wheel makes no difference, but 2WD or 4WD, with or without P/S does.
1978/79's use different steering wheels and horn pads than 1971/77's.
1975/77 F100/350's & Econolines with Speed Control use a different steering wheel, T/S switch and horn pad than like 1975/77's without Speed Control.
*1973/75 F100/250 4WD's do not use a rag joint. The lower steering shaft and coupler connects to the input shaft of the steering gear box with a clamp and thru bolt.
Thanks Bill, do you know what the spline count and diameter is for the 78/79 steering wheels? And do you know what the steering wheel spline count and diameter is for a 70' F600? I'd like to put the F600 wheel in my f250.
Originally Posted by oddfordjunkie
I'd love to get it from you if you don't want it, it will not last if it's at Tacoma P&P so buy it then hem-n-ha about doing it.
The yard it's at lets them sit for at least 6-8 months before they finally crush it, it's safe. I'll grab it and let you know if I decide not to use it.
