Adjusting coil spring
Old Mar 30, 2019 | 01:59 PM
Follmerpa's Avatar
Follmerpa
How can i adjust this coil spring to make it fit? To me it looks like too much spring but O Reilly says its the right one for my 96 f 150 also had to replace the shock bracket and i dont think it comes out far enough from the frame. Any help ?
Thank you in advance.
Old Mar 30, 2019 | 02:05 PM
Conanski's Avatar
Conanski
I think you may have the spring installed upside down. Can you post some more pictures of the whole setup?
Old Mar 30, 2019 | 02:43 PM
timbersteel's Avatar
timbersteel
I agree. That spring looks upside down.
Old Mar 30, 2019 | 02:55 PM
Follmerpa's Avatar
Follmerpa
Driver side
I
Old Mar 30, 2019 | 02:57 PM
Follmerpa's Avatar
Follmerpa
The paper work that came with springs said install tighter coil springs to the top.
First time doing springs
Old Mar 30, 2019 | 03:07 PM
timbersteel
Spring looks correct as far as install. First pic looked like it was upside down.
What part number are the springs?
Old Mar 30, 2019 | 03:45 PM
Follmerpa's Avatar
Follmerpa
[QUOTE=timbersteel;18570869]Spring looks correct as far as install. First pic looked like it was upside down.
What part number are the springs?[/QUOT
E]
Sorry dont have the part numbers threw away box he said they would raise my front end about an inch or so. The rear of my truck has a extra leaf spring so it sits a little higher than the front. I just dont think these springs work for quad shocks
Old Mar 30, 2019 | 03:46 PM
Conanski's Avatar
Conanski
Not the right springs, they look to be visibly longer than the originals.
Old Mar 30, 2019 | 04:14 PM
timbersteel
I just checked their site. On my showed 4 that are for that truck. Only 1 set stated not for use with dual shocks. Perhaps that is what they sold you.
And you can call them and they can pull the part number up that you bought. They do it for me and they can go back 7 years.
Old Apr 1, 2019 | 09:06 AM
speedfreak78's Avatar
speedfreak78
Unbolt the shocks and see if they're holding things down. You might need shock extensions or longer shocks if those are lift springs. I don't see how the quad shock option matters, there looks to be plenty of clearance around the spring.
fairfield86f150
Apr 13, 2012 11:55 AM
pburress
Apr 2, 2012 11:13 PM
Jaykane
Mar 31, 2011 06:25 PM
Old F1
Apr 19, 2009 09:20 PM
