Quick question about brake calipers...
Old Mar 29, 2019 | 02:27 PM
numba1killa's Avatar
numba1killa
Hi guys, hope you're all enjoying your Fridays!
I have a quick question about front brake calipers...
I have a 1978 Ford F-250 2WD, 351m, with single piston calipers, and when I look on ebay to purchase some, most sellers do not list them as LEFT or RIGHT, but when I check Rock Auto, every variant lists LEFT and RIGHT.
I checked my haynes manual, and it doesn't list any difference between LEFT and RIGHT single piston calipers...
Any ideas guys?
Thanks and have a great weekend
numba1
Old Mar 29, 2019 | 03:27 PM
caravaggio2000's Avatar
caravaggio2000
I'm not sure on a F250, but on my 73 F100 with discs they do have different part numbers.
On Amazon...
https://www.amazon.com/gp/product/B000C46B5M/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000C46B5M/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B000C41AYE/ref=ppx_yo_dt_b_asin_title_o06_s01?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000C41AYE/ref=ppx_yo_dt_b_asin_title_o06_s01?ie=UTF8&psc=1
Also, if you are getting new rear wheel cylinders, they too have left and right part numbers.
Old Mar 29, 2019 | 03:45 PM
tbear853's Avatar
tbear853
They are different numbers, as brake hose enters below the bleeder screw. Bleeder screw is up high when mounted correctly, air bubbles up as well.
The calipers will physically fit either side, but hose and bleeders will be wrong if not correct side mounting.
https://www.ford-trucks.com/forums/1...e-upgrade.html
Old Mar 29, 2019 | 03:54 PM
fordguy2100's Avatar
fordguy2100
As to rear wheel cylinders, I even swapped over from 1/2 ton F150 to 3/4 ton F350 RWC, same on each side. But yes calipers on front, differ right vs left.
Rear wheel cylinders won't interchange from right and left because the brake hoses will come in at different angles. swapping cylinders (if on the wrong side) will have the brake hose coming in from the wrong direction. I suppose you could bend a line to fit...
Old Mar 29, 2019 | 05:22 PM
Blue and White's Avatar
Blue and White
On something like that, hard to beat your local parts store. Order, check/compare when you pickup and happy. They might well be in stock also.
Old Mar 29, 2019 | 07:13 PM
numba1killa
Thanks for the replies guys, appreciate it. I've already replaced the ***-end of the truck and thankfully eBay told me which wheel cylinder was which!
thanks again,
numba1
Old Mar 29, 2019 | 07:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have a 1978 Ford F-250 2WD with single piston calipers, and when I look on ebay to purchase some, most sellers do not list them as LEFT or RIGHT, but when I check Rock Auto, every variant lists LEFT and RIGHT.
Same Single Piston Calipers: 1973/74 E100 / 1973/79 F100 2WD / 1975/79 E100/150 & F150 2WD / 1976 F100 4WD / 1976/79 F150 4WD
1) D3TZ-2B120-A .. Right Caliper Assy / Obsolete
1) D3TZ-2B121-A .. Left Caliper Assy./ Obsolete
Pic: Scroll down to PARTS LIST #17, then scroll down to the bottom of the page.
Old Mar 29, 2019 | 09:40 PM
tbear853's Avatar
tbear853
Thanks …. I thought they came straight in between mouting bolts, but you are right … I did use different numbers right and left. Reading your reply caused me to look back at notes. I fixed my post. Yeah, could bend a line, but not needed.
Fifty4F100
2004 - 2008 F150
Mar 6, 2018 04:35 PM
Donebrokeit
Apr 13, 2016 01:43 PM
mikeismadness
Oct 25, 2012 08:56 AM
jwl379
Nov 17, 2011 02:33 PM
fomocofan
Apr 2, 2007 11:50 AM
