Brake drag
Old Feb 26, 2018 | 07:11 PM
Fifty4F100's Avatar
Fifty4F100
Brake drag
Do very randomly my truck's front drivers side brake is dragging. Sometimes lightly, sometimes (like today) enough to shake the steering wheel and pour smoke from the fender. Then like today it stops and rolls fine.
What is causing this?
Old Feb 27, 2018 | 07:27 AM
Shadow351's Avatar
Shadow351
These trucks a notorious for sticking front calipers, I think it is because they use a phenolic piston, but I can't say for sure. I replaced both of my front calipers when they started hanging up, but mine weren't intermittent, they were constantly hanging up causing the truck to reek of burning brakes.
However, it could also be caused by a bad brake hose. If you catch it while a brake is hanging, jack up the wheel and try to turn it (get a feel for how much it is dragging, or if is even possible to turn by hand) then, crack the brake bleeder. if you can turn the wheel now, then the caliper is probably ok and the next likely suspect is the rubber brake hose.
Old Feb 27, 2018 | 07:54 AM
projectSHO89's Avatar
projectSHO89
Replace both the caliper and the hose.
Old Feb 27, 2018 | 12:59 PM
Fifty4F100's Avatar
Fifty4F100
Got everything going back together. But what is the small bolt that's on the hose fitting right at the bracket? The one on the old hose was tight, the one on the new hose seems like brass and is loose.
And does it matter which pin goes where? I didn't pay attention to the fact that there were 2 different pins!
Old Mar 6, 2018 | 03:47 PM
redfishtd's Avatar
redfishtd
Replace both calipers
They will ruin your rotors and wheel bearings . I fought this after a brake job . Seems piston being out absorbs moisture after pressed back in it sticks intermittently .
Old Mar 6, 2018 | 04:35 PM
Fifty4F100's Avatar
Fifty4F100
I replaced caliper, brake hose, and of course the pads. My rotor seemed fine. Now I wondering how long it will be before the passenger side goes out.
mikeinri
Jun 29, 2015 07:48 AM
mikeismadness
Oct 25, 2012 08:56 AM
doesntmatter
1983 - 2012 Ranger & B-Series
Nov 5, 2010 11:30 PM
kystangbanger
Mar 22, 2010 06:27 AM
fomocofan
Apr 2, 2007 11:50 AM
