Turn signal/Emergency flasher switch Part Number?
1967 E-100 Econoline.
Could someone supply me with the Ford, or aftermarket Part # for the Turn Signal/Emergency Flasher Switch? The one located in the steering column below the wheel.
Also, is the switch unique to the 67 Econoline only?
I believe all the older Econolines had the Emergency Flasher switches remotely located on the dash, and by 1968 the Econolines were the Second Generation and would probably have used a different column than a 67, would this be correct?
Thanks, Bret
Thanks, Bret
C7TZ-13341-E .. Column Mounted T/S & Emergency Flasher Switch with Transistorized Flasher / Obsolete
1967 E100 before serial number B82,001.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
C7TZ-13341-G .. Column Mounted T/S & Emergency Flasher Switch with Double Flasher / Obsolete
1967 E100 from serial number B82,001.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
eminencefront
10-01-2014 10:28 AM
thunderbirdcakes
09-24-2012 12:26 PM
riskman
05-28-2010 08:43 AM
tl1965
09-01-2009 08:11 PM
