Turn signal switch
Old Sep 24, 2012 | 02:00 AM
thunderbirdcakes's Avatar
thunderbirdcakes
Turn signal switch
So I found out I need to replace my turn signal switch. Looked up the part from National Parts Depot and discovered they offer for my year and truck (1978, A/T, fixed column) a turn signal switch assembly or a switch assembly "replacement". The replacement being $42 cheaper. What's the difference between the two? Do I just need the replacement? Any help would be awesome. The NPD part numbers are F-13341-11 (switch assy) and F-13341-11A (switch assy replacement).
Old Sep 24, 2012 | 02:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
How much is the non replacement switch? If it's roughly $110.00, it's genuine Ford / The replacement is probably an autoparts store generic "fitz-all."
Genuine Ford parts / 1978/79 F100/350, Bronco & Econoline:
D8TZ-13341-A .. T/S Switch ~ Use with Tilt Column / Obsolete ~ 14 available NOS
D8TZ-13341-B .. T/S Switch ~ Use with A/T with Fixed Column / Available from Ford / Memphis TN Ford parts depot has 123.
MSRP: $110.00 // FTE sponsor tousleyfordparts.com price: $72.60.
D8TZ-13341-C .. T/S Switch ~ Use with M/T with Fixed Column / Obsolete ~ 18 available NOS
Fixed Column = No Tilt Steering Wheel / Some people are unaware they have a Tilt Wheel, because it's operated by pushing the turn signal handle...forward.
Old Sep 24, 2012 | 02:46 AM
thunderbirdcakes
The non replacement is $110 and it states that it is an original part. I'll check with the tousley ford site. Thanks!
Old Sep 24, 2012 | 02:51 AM
NumberDummy
Tousley Ford = White Bear Lake MN / Look at their discounted price again. Their website was down, I guessed that their discount price was $77.00, but it ain't.
Website is back online, their price is: $72.60.
Old Sep 24, 2012 | 02:56 AM
thunderbirdcakes
I was stating that the NPD part was $110. Just looked at the tousley site and got the $72 offering. Thanks again!
Old Sep 24, 2012 | 03:08 AM
NumberDummy
MSRP: Manufacturers (FoMoCo) Suggested Retail Price: $110.00.
NPD is buying the switch from a Ford Dealer, probably at cost + 10% = $72.60!
Old Sep 24, 2012 | 12:09 PM
Ole Blue (Pete)'s Avatar
Ole Blue (Pete)
Thanks for the info folks, I think I'm gonna be doing this one soon too.
Old Sep 24, 2012 | 12:26 PM
fmc400's Avatar
fmc400
MSEE
Often times with turn signal switches, you can buy the entire switch, or just the cam for much cheaper (which is also the part that breaks the most). However, the price difference is usually much more than $42 - so maybe that's not the case here.
Nonetheless, I recommend replacing the entire switch instead of splicing in a new cam. The wiring in turn signal switches is too tight and must snake around too many corners for a solder splice to make it in there without getting caught.
Bret (OH)
Mar 27, 2019 05:05 AM
goodm3
Sep 24, 2018 07:30 PM
lakatco
Nov 20, 2016 01:08 PM
eminencefront
Oct 1, 2014 10:28 AM
David A
Feb 27, 2005 09:49 AM
