Turn signal/Emergency flasher switch Part Number?
1967 E-100 Econoline.
Could someone supply me with the Ford, or aftermarket Part # for the Turn Signal/Emergency Flasher Switch? The one located in the steering column below the wheel. Also, is the switch unique to the 67 Econoline only? I believe all the older Econolines had the Emergency Flasher switches remotely located on the dash, and by 1968 the Econolines were the Second Generation and would probably have used a different column than a 67, would this be correct? Thanks, Bret |
Originally Posted by Bret (OH)
(Post 18561694)
Could someone supply me with the Ford Part # for the Turn Signal/Emergency Flasher Switch? The one located in the steering column below the wheel. Also, is the switch unique to the 67 Econoline only? :-X22 C7TZ-13341-E .. Column Mounted T/S & Emergency Flasher Switch with Transistorized Flasher / Obsolete 1967 E100 before serial number B82,001. NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746. ----------------------------------------------------------------- C7TZ-13341-G .. Column Mounted T/S & Emergency Flasher Switch with Double Flasher / Obsolete 1967 E100 from serial number B82,001. NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201. GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959. |
Thank you Bill, your services are much appriciated.
