Starter Relay Bad?
Old Mar 24, 2019 | 06:13 PM
harrythehack's Avatar
harrythehack
Starter Relay Bad?
Helli Ford Friends,
My 2 year project on my 1979 Ford F 150 is nearing the end. I went to turn the key and nothing happened. I installed a new one cable alternator and starter, new battery. The starter relay is older
I'm thinking it might be bad. Is there anyway to test the starter relay? Thanks.
Old Mar 24, 2019 | 06:52 PM
fordguy2100's Avatar
fordguy2100
Originally Posted by harrythehack
Helli Ford Friends,
Put a rubber handled screwdriver across the posts. If you can start it then, then it's bad. If it doesn't start then it could be your starter wired wrong, ignition switch, or ignition module, or ignition coil, or bad wiring anywhere in between
Old Mar 27, 2019 | 02:51 AM
harrythehack
Thank you.
Follmerpa
Jan 22, 2019 09:11 PM
Chris_stanworth
1983 - 2012 Ranger & B-Series
Jun 18, 2017 07:33 AM
LSO1123
Sep 1, 2011 01:36 PM
TGCRVT
22
Sep 17, 2010 09:03 PM
zzrich
Dec 16, 2005 11:05 AM
