Hey guys. I have a friend with a Explorer that will not turn over when the key is turned. But, if the key is on I can short the starter relay and it fires right up. We replaced the starter relay and the same thing happens. Could this be a bad ignition switch ? What else could cause this ? It seems that the starter is fine. What do you guys think ?
What 'starter relay' did you replace? Are you talking about the solenoid located on the firewall(might be the fenderwell)? Have you checked all the cables?
It must be the season..I'm having the same problem. Replaced the ignition module, and now can hear it and the relay on the fender click, but still wont crank or click the starter. Pulling it today to check the solenoid..but still, check around, other people had it happen because of wiring harness' melted on the manifold, faulty voltage regulators, low batteries, bad wires, etc, etc. Enough that I'm dreading going outside and trying to figure it out :/
There also appears to be a jumper where the clutch switch would be (assuming it's an automatic, I didn't notice where you said, but most were automatics). You should be able to check for voltage at the neutral switch and at the clutch switch jumper when the key is turned to the start position. If there is no voltage there (12 volts), it's probably your ignition switch. You can also check your neutral switch by jumping across it. When you spoke of jumping the solenoid, are you talking about jumping + to the small terminal to make the solenoid engage, or are you talking about jumping across the two big posts? Jumping the two big posts eliminates the solenoid, so it could still be your problem if that's how you tested (I have gotten bad new parts before, but not often).
I just finished fixing mine..ends up a nut for the ground came loose on the solenoid, didn't notice it when I pulled it. Cleaned er up, put it back in, starts fine. Make sure there's 3 wires going to it!
Thanks for all the replies guys. I will perform some of the tests that were suggested and post back later. As far as the part that was replaced, it is what I would normaly call the starter solenoid located on the passenger side fender well. I shorted out the large positive post to the smaller one to get it to turn over.
Quick & simple test. Pull the wire with the rubber boot off of the starter relay & jump 12 volts to that terminal. If it cranks, the problem is somewhere between the ignition switch & the relay.
Most likely a bad neutral safety switch.
Edit, everything that you need to figure this out is in that excellent wiring diagram that Jerry linked to.
In my experience the most common cause of no-starts/starter issues is bad connections (usually grounds). There may be other issues as the fellas have said but before going nuts on parts and diagnosis make sure every connection is clean and tight. Have the battery checked too. Check both ends (at battery and at starter). Look for corrosion or breaks along the cables going down to the starter.
If it ends up beign a starter/solenoid that job takes about 15 minutes but try the obvious first.
