I also have a 13' w/a 5.0 & recently switched from my 87 tune to a 93 tune.
I picked up a can of "Royal Purple Max Boost Octane Boost" as the truck had appx 1/4 tank (8 gal) of gas left. I dumped that in & filled the tank with Premium, then drove home before uploading the 93 tune. My truck never had any issues afterwards. I will say that the Royal Purple seemed to have the biggest # gain & most do not have the expected gain printed (which means not **** IMO). The printed gain is "up to 30 points, 3 numbers" (it takes 10 points to equal 1 octane value) so technically that should only boost my old 87 to a 90. My thought was I was only boosting 8 gallons & the can treats up to 25 gallons, which is nearly x3 of what I needed. Not sure if thats a correct way to think, but the truck ran great. Hope this helps
