rpm question
Old Mar 23, 2019 | 03:55 PM
grumpyinme.'s Avatar
grumpyinme.
rpm question
I have a 94 f250 4x4,4:10 gears e4od and a mighty 7.5 what is a safe rpm at turnpike speed,right now on the factory tach the engine is turning ahout 2400 at 75.
Old Mar 23, 2019 | 07:14 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Ok. Safe for what exactly? It will run at that rpm all day long.
Old Mar 23, 2019 | 10:07 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A safe RPM is one that the engine will run at. The computer will not allow the engine to run at an unsafe RPM. It will turn off the injectors before it can exceed the safe speed.
Old Mar 24, 2019 | 01:14 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
It's probably sucking a good deal of gas at that speed but as long as the engine is in decent condition, it will hold together.
Old Mar 24, 2019 | 10:09 AM
grumpyinme.
I never owned a big block,dont want to hurt it,as for the condition of engine 124,000,uses 1/2 qt. of oil every 3k,and at that speed empty on turnpike I an get 12.5mpg.she runs fine.I am the 2nd owner,never seen bad winter roads,put up for winter since new.thanks for your imput
Old Mar 24, 2019 | 10:10 AM
grumpyinme.
I did not know about the computer,thanks,Mark
Old Mar 24, 2019 | 10:21 AM
MPP8405's Avatar
MPP8405
This is where the engines computer has a designated redline and will either cut fuel or spark to keep the engine within its normal operating range in RPMs, this is NOT what you want to use as a guideline, your best bet is to look at the factory HP and torque ratings for your 94 460 and see where the peak HP is made at a certain RPM usually around 3500-4000rpm and keep that as your max working RPM, reason being the engine is not making any more power above those RPMs and will be wasting fuel and putting uneeded wear and tear on the engine internals.
Old Mar 24, 2019 | 12:57 PM
Conanski's Avatar
Conanski
Is that safe for the engine or safe for your pocketbook? LOL
Old Mar 24, 2019 | 01:14 PM
My4Fordtrucks
According to driverside.com the peak torque for a ‘96 460 is 395 @ 2400 and 245hp @ 4000. I’d think a ‘94 would be fairly close to those specs. An engine is most efficient at peak torque so you are right where you need to be.
Old Mar 24, 2019 | 01:15 PM
grumpyinme.
she has 2 tanks and likes them too,lol
dbdbb
Flathead V8 & Flathead 6
Dec 6, 2010 09:28 AM
tcf26
Modular V10 (6.8l)
15
Mar 27, 2007 03:37 PM
1978fordf250
Nov 6, 2006 10:41 PM
