Disappearing coolant
Old Mar 23, 2019 | 11:06 AM
RigCity's Avatar
RigCity
my truck was a couple inches low on coolant for some time; yesterday I brought it up to the full when cold mark. Yesterday I drove about 200 towing something miles I just looked at the truck and it dropped a 3-5 mm from the full when cold mark. Coolant appears good,oil cooler was rebuilt 4 years ago for PM, does not appear to be any coolant leaks, or coolant in the oil. The Truck is also operating as usual. Could there be coolant evaporating because my cap is bad?
Thank You
Old Mar 23, 2019 | 11:27 AM
derek0525's Avatar
derek0525
I have had the same issue for about 10 years always stops at same level about 1/2 inch below the minimum level cant see it leaking anyplace figured it was the degass bottle had a leak but could never find anything.
Old Mar 23, 2019 | 12:56 PM
seville009's Avatar
seville009
Yes - could be the cap. Was having the same issue on a Taurus; new cap and no more disappearing coolant.
The caps cost about $7, so I put new ones in all my vehicles
Old Mar 23, 2019 | 01:19 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Normal.
1/2"-1" below minimum line and the pickup will find its happy place.
Old Mar 23, 2019 | 05:04 PM
'88 E-350's Avatar
'88 E-350
It could be that it had some air to displace from being a few inches low. Mine seemed to have disappearing coolant for a few drives after topping off before it settled in, it now seems to be staying about midway between the lines.
Old Mar 23, 2019 | 08:45 PM
F350-6's Avatar
F350-6
I'm with cleatus. These trucks seem to like to ignore the marks on the degas bottle. Let it drop to "low" and see if it levels off. Most of them find a happy spot below "full" and stay there.
Old Mar 23, 2019 | 09:44 PM
RigCity's Avatar
RigCity
Now that I had coolant on hand I topped it up before posting. It was not topped up initially as some fluid was lost when replacing the OC gasket and the SCA tested good afterwards. Of course it was a nominal amount of truck food to add a minor amount of coolant lol. SCA test kit order, additive, coolant concentrare, and distilled water lol I’m going to let it settle where it lands
Old Mar 23, 2019 | 10:01 PM
dmd's Avatar
dmd
Why not just switch to the red CAT stuff?
Old Mar 23, 2019 | 10:34 PM
Cartel's Avatar
Cartel
PRESTONE COMMAND? says its good for 600,000miles!
Old Mar 23, 2019 | 10:47 PM
JT250's Avatar
JT250
Originally Posted by cleatus12r
Normal.
Same (add characters)
Old Mar 23, 2019 | 11:53 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
IIRC the early years (I forget the cutoff year) the sealant used on the injector cups will melt away with the ELC. So research is needed.
Have not checked recently but the cost of ELC was like 2X that of green or gold. Even if it runs 600k your water pump won't, so replacing it is pricey.
All that said I might switch to ELC when this water pump dies. Mine came with gold coolant so the switch is easier. Green coolant requires pretty rigorous flushing since they don't mix well. There are some really good threads on this subject by way more edumacated folks than me.
Old Mar 24, 2019 | 02:08 AM
'88 E-350's Avatar
'88 E-350
I think the change happened in mid 2000 model year.
The red ELC is indeed about 2x $.
I didn't do any special flushing and haven't noticed adverse effects, but maybe the super long life of the red ELC has been compromised by residues of the old green that was in it, don't know. I doubt I'll run it long enough for that to matter.
Old Mar 24, 2019 | 06:32 AM
tjc transport's Avatar
tjc transport
i ain't rite
my 02 uses around 1 gallon a year. been like this since i got it 11 years ago. no visible leaks, no smell.
i just add a gallon every spring.
Old Mar 24, 2019 | 07:59 AM
RigCity's Avatar
RigCity
My truck came with ELC when I had a diesel mechanic intitiTially he said aftertesting the SCA was way out of whack. He converted it back to green. Since then I added new coolant the few times I was working on coolant related stuff. I’n the middle of those projects flushing and converting to ELC is the last additional job I want to do. Lol I may convert back in 20 k miles or so once the current coolant is a bit older.
Old Mar 24, 2019 | 08:08 AM
Tugly's Avatar
Tugly
Good call.
