Disappearing coolant
Old Mar 24, 2019 | 10:56 AM
RA101725's Avatar
RA101725
Banned
Originally Posted by aawlberninf350
IIRC the early years (I forget the cutoff year) the sealant used on the injector cups will melt away with the ELC. So research is needed.
Have not checked recently but the cost of ELC was like 2X that of green or gold. Even if it runs 600k your water pump won't, so replacing it is pricey.
All that said I might switch to ELC when this water pump dies. Mine came with gold coolant so the switch is easier. Green coolant requires pretty rigorous flushing since they don't mix well. There are some really good threads on this subject by way more edumacated folks than me.
I wish I could switch to the red stuff but mine is the earlier one so I'm not going to play with that fire. If the injector cups are replaced with the updated sealant I think I read it is okay to switch then if wanted, but that is not a job I would mess with unless it was absolutely necessary.
Old Mar 24, 2019 | 11:00 AM
RA101725's Avatar
RA101725
Banned
Originally Posted by RigCity
my truck was a couple inches low on coolant for some time; yesterday I brought it up to the full when cold mark. Yesterday I drove about 200 towing something miles I just looked at the truck and it dropped a 3-5 mm from the full when cold mark. Coolant appears good,oil cooler was rebuilt 4 years ago for PM, does not appear to be any coolant leaks, or coolant in the oil. The Truck is also operating as usual. Could there be coolant evaporating because my cap is bad?
Thank You
It could be something as simple as an old cap not holding pressure. If you get the engine up to full operating temp and don't hear the loud hiss of pressurized air escaping when you start to twist the cap off, that is a clue it is bad.
Old Mar 24, 2019 | 12:26 PM
socal_pzy's Avatar
socal_pzy
I've been wanting to ask this exact same question ever since I got the truck.
Im going to try a new cap.
I've been wanting one of those metal tanks, but for $275 it's not worth it yet.
Old Mar 24, 2019 | 02:36 PM
RA101725's Avatar
RA101725
Banned
I personally wouldn't spend that much on one those tanks. You can get a new OEM one for around $50 I think and they are easier to see the level or any oil or fuel contamination.
Old Mar 26, 2019 | 09:30 AM
brian42's Avatar
brian42
Veteran: Navy
Thank You
It is a phenomenon that most of us have noticed but I don't think any of us have figured out. Mine also seems to find it's happy place a little below the minimum cold fill line. I've never had a cooling issue and never found where it could be going. Over the years I've replaced the degas bottle, cap, hoses, water pump, and injector cups and still have the "issue". It's just one of those things that I stopped worrying about until it shows up on the ground or in my oil.
Old Apr 1, 2019 | 11:11 AM
Josh Ross's Avatar
Josh Ross
Diverdude
Me too. Thankfully no contamination.
Old Apr 3, 2019 | 08:38 AM
RigCity's Avatar
RigCity
I ordered up a new Ford cap put it on coolant is dripping onto the front axle. It also appears to be leaking onto the two grounds I recently re-did the oil cooler about 6 to 8 months ago . I’m going to use a boroscope later and then start
Old Apr 3, 2019 | 08:51 AM
brian42's Avatar
brian42
Veteran: Navy
Weep hole from the water pump maybe?
Old Apr 3, 2019 | 09:16 AM
RigCity's Avatar
RigCity
I’m hoping not another autotrash the p/o put on I replaced about 2-3 years ago with s motorcraft punp
Old Apr 3, 2019 | 09:50 AM
StrokedRanchero's Avatar
StrokedRanchero
My e'99 has been doing the same thing too for the past year. I replaced the wp because it needed one. seemed to be fine for awhile.For the past 6 mos. been noticing small leak in the driveway but the level seemed ok. At the same time did new fan & clutch, hoses, Dorman degas bottle & cap. I have had to add a little every couple of wks to bring it up to proper level. The other day I was at the store & came out to see it dripping underneath on the front pass. side. I opened the hood everything on the upper eng. was soaked toward the pass. side. I highly suspect a seam on the de gas bottle.
Old Apr 3, 2019 | 11:25 AM
Firefighter 1406's Avatar
Firefighter 1406
That would be my guess. Get it figured out quick. My truck went from drops to gushing coolant real quick.
Old Apr 3, 2019 | 05:57 PM
dn29626's Avatar
dn29626
I am a one owner trucker. The full mark is in the wrong place , from the factory, too high on the bottle.
This has been discussed many times here.
nmclella
Dec 29, 2015 10:10 AM
StanleyZ
6.4L Power Stroke Diesel
51
Oct 26, 2014 09:30 PM
capt caper
97
Oct 19, 2012 12:36 AM
rayezra
Oct 18, 2009 03:39 PM
mechelement
Feb 15, 2009 08:30 PM
