Carb. Recommendations??
Old Mar 23, 2019 | 08:44 AM
Jpegg01's Avatar
Jpegg01
So I bought a fuel pressure gauge, and pressure looks to be 9psi, is that good or bad?
Old Mar 23, 2019 | 09:11 AM
lafermedavid's Avatar
lafermedavid
I believe eldebrock mechanical fuel pumps are regulated for their Carbs. which I think is 6 psi
Old Mar 23, 2019 | 09:50 AM
Jpegg01's Avatar
Jpegg01
Okay, so I go and buy a new regulator since obviously mine old is failing. I put new regulator on and still shows 9psi even though its turned down to 1psi. So at this point I dont know what right or wrong. Regular is only adjustable from 1 to 6psi. My pressure gauge is brand new, I was going to get new pump as well since old one is 4-7psi. I thought if I have 9psi then the pump is bad as well, however pump is only 2.5 months old.
Old Mar 23, 2019 | 12:29 PM
matthewq4b's Avatar
matthewq4b
What elec pump did you buy ?
Old Mar 23, 2019 | 12:43 PM
Jpegg01's Avatar
Jpegg01
It's an edlebrock from orielly, it was about 50bucks
Old Mar 24, 2019 | 09:59 AM
Jpegg01's Avatar
Jpegg01
So to check my pressure I simply remove fuel line from carb, and plugged it up to Vacum/Fuel pressure gauge and get almost 10psi. I bought a new mr. Gasket regulator and turned it down to 1psi and it makes no difference. I haven't checked pressure In-line with engine running. I figured the regulator should keep pressure down 100% of the time. At 10 psi to carb. that seems to me it is to much and can be unseating my valve seat allowing carb to overfill. Any thoughts??? Maybe buy a better regulator???
Old Mar 24, 2019 | 12:22 PM
Bukwheet's Avatar
Bukwheet
You need to check the fuel pressure while the engine is running, and the fuel is flowing into the fuel bowls. What you are doing now is "deadheading" the pump, and the pressure is creeping up, which is normal. The pressure should drop down once the fuel starts flowing through the regulator. Connect your fuel pressure gauge so that it is inline, and between the regulator and the carburetor. That will get you an accurate measurement of the pressure going to the carb.
Old Mar 28, 2019 | 01:11 AM
niko20's Avatar
niko20
I have an edelbrock 1405 and rebuilding is easy , id never rebuilt a carb before and i did it no problem, kit is $45. I also have it on a 460 and it runs great. Stock mechanical pump
Old Mar 28, 2019 | 04:05 PM
SlikWillie's Avatar
SlikWillie
This is just me thinking here, but if you are going to buy a new electric fuel pump and regulator, why not just buy a mechanical fuel pump for much cheaper and it will supply the correct psi. As for the carb, I would get a 650cfm to help the 460 breath easier. It really doesn't matter what brand you use. You had an Edelbrock on before, I would stick with Edelbrock. Should be a direct replacement. The Edelbrock 1906 is $370 at SR.
https://www.summitracing.com/parts/edl-1906/overview/
Nickdallas85
13
Nov 21, 2017 08:05 AM
Dads76XLT
Jul 28, 2017 03:30 AM
dorf dude
Feb 17, 2013 08:04 AM
1978-BBB
Jan 22, 2012 05:36 PM
soundman502
27
Mar 9, 2007 03:40 AM
