'77 no power to cab
'77 no power to cab
1977 F150, 390, 2wd, C6. This truck had sat for about a year. It ran like a beast when I put it away, but the battery must have gone bad during that time. I went to use my 300 amp booster. It was dark, both battery cables were black, and long story short, I fried the battery with reversed cables. (Trust me, nothing you could say to me would be worse that what I called myself afterwards).
So since then, I've replaced the battery, replaced the battery cables and checked the ground, replaced the solenoid, replaced the voltage regulator, and checked all the bus fuses in the cab (they're good)
I can jump the solenoid with a pair of pliers and it turns over strong, but I get no spark, like the ignition key is off. There is no accessory power or direct power, no dome lights no headlights, no radio. I'm kind if out of ideas.
Check the fusible links. When they get fried, the truck loses all power. I know there's at least one, a '77 might have more.
Look on the battery side of the starter solenoid, there will be several smaller wires going into the alternator harness. At least one of these will have a "FUSIBLE LINK" flag on it. check to see if it's burned out. Tug on it and see if it stretches, if it does, it's bad. New ones are available from the auto parts store. You'll need to splice it in.
Sorry for the lack of follow through. Since the OP, all my time off was either rain, freezing rain, or snow. Next dry day off I'll dig into it. I'm really hoping there isn't one under the dash. The last owner replaced the entire interior, and it's a bird's nest under there. Will post info when I get it.
Juno_F250
24
08-16-2014 09:33 AM
Bayou_bike87
05-02-2014 09:27 AM
ctvanover
03-12-2013 10:32 PM
jimbo beam
02-28-2008 10:14 PM
