leaking trans. gasket
Old Mar 21, 2019 | 11:37 PM
mike L's Avatar
mike L
About how much trans.oil should I have pick up for this job, I read 6 quarts? Do I use Mercon V atf? Do I use the 20 bolt gasket like this one, https://shop.advanceautoparts.com/p/...8688/5992028-P
Thanks for your help!,
AT, E4OD, 5.0, 93 F150
Old Mar 22, 2019 | 01:04 PM
jas88's Avatar
jas88
If you are just changing the pan gasket, it's going to be like 4-5 qts. However, your TC has a drain plug, I recommend you drain that as well, then you are talking about 12-14 qts. total. You can use the cheap stuff labeled "ATF" as your trans takes Mercon III. Don't waste your money on Mercon V is my advise.
Oh yeah, if you do drain the converter, when you are putting the fluid back in, don't dump all 12 qts in at once. You put in about 6-7, start it up and let it run for about 30 secs, then put the rest in. Otherwise you will overflow the pan and ATF will start coming out the air vent.
Old Mar 22, 2019 | 01:38 PM
BeholdenZippy's Avatar
BeholdenZippy
I recommend that you don't use a smooth rubber gasket. In my experience, they always leak. Either get a cork gasket and torque it to 100 INCH pounds(corks gasket can't take any more torque) or go to Ford and get their ribbed rubber gasket(it's also reusable).
Old Mar 29, 2019 | 09:09 PM
mike L's Avatar
mike L
Is super tech at walmart ok to mix with oem I don't see. I don't see Super Tech Mercon 3 ATF ? I see ATF- Dexron 3 but it's the same price as Mercon 5 about $12.00?
Old Mar 29, 2019 | 11:24 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Mercon V is superior ATF.Use that.You can use a ATF meeting "MERCON" spec and it wont kill your trans though.
Old Mar 30, 2019 | 12:08 PM
mike L's Avatar
mike L
maxlife dextron 3
Is Maxlife Dextron 3 ok to use with just a filter change? It's only $6.50 a quart. I just want to fix the leaking gasket. The truck is not going to last much longer.
Old Mar 30, 2019 | 01:20 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I’m a little confused....doesn’t the container say Dex/Merc on it? That would meet Dexron III / Mercon specs and be ok to use. Either that or use Mercon V.
Old Mar 30, 2019 | 02:03 PM
sandymane's Avatar
sandymane
I am a proponent of Felpro gaskets but my bro in law advised me to go cork. He offered to replace it if it leaked and he hates ATF. He has been right so far. Sandy
Old Mar 31, 2019 | 03:00 AM
mike L's Avatar
mike L
gasket to used cork or rubber for trans?
Will a Carquest rubber gasket from advance last a long time? Do I add Permatex trans.RTV to both sides of the gasket, tighten finger tight wait an hour then torque the bolts, to what Haynes manual says.
Or just skip the gasket and just use trans. RTV, and not torque the bolts but instead a 1/2 turn more of the bolts after waiting an hour.
Old Mar 31, 2019 | 10:09 AM
My4Fordtrucks
No. Do not put RTV on a rubber gasket.
I would put a couple dabs of RTV on the pan to hold the cork gasket in place and then torque the bolts to spec. Done.
Old Mar 31, 2019 | 11:28 AM
mike L's Avatar
mike L
thanks..................
Old Mar 31, 2019 | 02:08 PM
FORDF250HDXLT
The main reason trans pans leak is because someone over tightened the bolts and or possibly warped the bolt hole surface.
Cork is fine but it's extra work in cleaning up and replacing it latter.That's why most prefer a good rubber gasket on valve covers and trans pans.Look up the torque settings and just do it right with a rubber gasket and it wonk leak.Just make sure to flatten the surface first with a hammer if needed.
SoCalAngler
22
Jan 15, 2025 09:35 AM
TXSailor
Jul 22, 2010 08:08 AM
tmuti13
2004 - 2008 F150
Feb 23, 2009 04:23 AM
dmcaudle
Dec 19, 2007 07:52 AM
mcisme
Apr 24, 2004 10:09 PM
