Mercon 5
Old Feb 20, 2009 | 09:20 AM
tmuti13's Avatar
tmuti13
Mercon 5
anyone running something besides mercon 5 in their tranny? I'm up for changing my fluid and filter. i've put royal purple in my mustang (its a 93)and like it, but i know that some of these newer transmissions are finicky. i've got an 06 fx4. thanks.
Old Feb 20, 2009 | 09:30 AM
motown's Avatar
motown
Unless it meets the Mercon 5 spec, your going to risk voiding your warrenty, and possible issues with your trans. I've found that even with the fluid a little low in these transmissions, they start shifting funny. I can always tell when the trans was low on fluid, with the shifts.
Old Feb 20, 2009 | 09:45 AM
tmuti13's Avatar
tmuti13
yeah, i just wanted to be safe. i'll probably go with the mercon 5. btw, do you konw if the pan gaskets are rubber or if they are rtv? Thanks.
Old Feb 20, 2009 | 06:22 PM
motown's Avatar
motown
Probably a cork type of gasket.
Old Feb 20, 2009 | 07:22 PM
Catmonkey's Avatar
Catmonkey
I just swapped out my valve body last weekend for Troyer's unit and filled it up with Mobil 1 ATF along with a larger aluminum pan. I used Mobil 1 in my prior Ford's going back a lot of years and never had any problems with it. It's not a cheap alternative, but it's good stuff. The pan gasket in my '08 was a reusable rubber/steel gasket.
Old Feb 22, 2009 | 07:34 PM
PJF150's Avatar
PJF150
Im sticking with the Mercon V.I would never use another ATF in my truck.Checkout this webbieMERCON® V Automatic Transmission and Power Steering Fluid
Old Feb 22, 2009 | 09:46 PM
Djack04F150XL's Avatar
Djack04F150XL
The pan gasket is a reuseable rubber/ steel one. As for the Mercon V fluid the Motorcraft or Valvoline are full synthetic and cost about $4.50/ Quart. I used Valvoline on my last 2 changes. I found out that the Motorcraft is about the same cost. I used Royal Purple in my P/S unit. Wish I had read the Mercon V Automatic Transmission and Power Steering Fluid web sight. Thanks, PJF150.
Old Feb 23, 2009 | 04:23 AM
magnet1's Avatar
magnet1
I use nothing but AMSOIL 100% synthetic in all my vehicles. Their ATF is better than anything else out there, runs cooler, less friction and wear, and its good for 100,000 miles. They also have a guarantee that if something goes wrong while using their product, and the dealer says AMSOIL fluids voided their warantee; AMSOIL will go to bat for you, and if they dont win, they will pay for repairs.
I also run their engine oil which is good for 1yr or 25,000 miles. Its alot more expensive, but with the intraval changes its cheaper. I am not a dealer, I have just seen too many instances where the the stuff has impressed me.
AmmoDawg
Jan 8, 2013 09:26 AM
1986fordrangerman
1997 - 2003 F150
Dec 31, 2008 06:02 PM
racsan
Oil & Lubrication
Jan 12, 2006 12:36 PM
50stang
Oil & Lubrication
Feb 21, 2005 07:43 AM
Joe Finn
1997 - 2003 F150
32
Mar 18, 2004 02:32 PM
