Sponsored by: Real Truck
Upfitter swicthes...
Old Mar 21, 2019 | 08:50 PM
Qwazert's Avatar
Qwazert
I have four of them....great!
How are these useful? Where do they terminate?
Old Mar 21, 2019 | 09:11 PM
Firefighter 1406's Avatar
Firefighter 1406
Very useful for adding lights, rear camera, high idle mod. They are prewired and fused. Inside the cab the wires will be located around the brake pedal area on the fire wall. They might be taped up to a look or bundle of wires. Engine bay side they are around the brake fluid resivior.
Old Mar 21, 2019 | 10:27 PM
Qwazert's Avatar
Qwazert
So there are termination points on the inside AND the outside of the cab?
Old Mar 21, 2019 | 10:35 PM
Firefighter 1406
I apologize. I was putting two different things together. There are pass through wires on the fire wall for wiring up additional things. The upfitter switched are all fused independently and can be used for adding accessory items. I still am pretty sure they are around the brake pedal. You will have a wire loom with like 4 or 5 wires visible but taped to the loom. If you google it there are tons of pictures.
Old Mar 21, 2019 | 11:48 PM
Qwazert's Avatar
Qwazert
OK, so basically they are just pre-wired HOT switches so that Joe Handyman doesn't have to butcher his dash....
Old Mar 23, 2019 | 12:43 PM
Firefighter 1406
Basically. I always find them useful.
aj3501
Oct 25, 2011 12:31 PM
5thwheel-in
6.4L Power Stroke Diesel
Aug 25, 2011 12:22 PM
mgomez
May 8, 2010 01:33 PM
g2giovanni
Nov 6, 2009 04:19 PM
