V10 FUEL PUMP CHANGE
Old Mar 21, 2019 | 07:24 PM
peenhead's Avatar
peenhead
'02 Ex with 6.8L had the fuel pump head south, replaced with an import pump and ran fine for a few days. Now I am experiencing sporadic difficulty starting. Also, does the '02 have a fuel pump relay, does not show in the owner's manual? Any advice appreciated, Thanks
Old Mar 22, 2019 | 06:18 PM
CalEx4x4's Avatar
CalEx4x4
Yes it does have a fuel pump relay but you're not going to like where Ford put it The quickest way to tell if the relay is sending power to your pump is on the passenger side foot well where the inertia switch is located. Pull off the panel and look for the Pink wire
coming out of it and poke a voltmeter in the socket to see if you have 14 volts, or close to it when you are cranking the starter.
Inertia switch in the passenger kick panel.
The Tiger
Sep 29, 2017 05:51 PM
bazzman1953
1983 - 2012 Ranger & B-Series
Jun 8, 2011 08:23 PM
Psychedelic_Wuff
Dec 29, 2010 03:07 PM
drudis
Feb 12, 2010 11:34 AM
jimlahey
Aerostar
Oct 9, 2005 01:53 PM
