Did you check the fuel pump relay?
If you're getting 12v at the Inertia Switch the relay is probably good.
I wasn't sure which relay is the fuel pump relay. Could you tell me? I wasn't able to determine this and the only thing that I could figure out was it is the same as the PCM relay based on the owners manual. Is that correct? I had a relay and I put a it in that place and nothing.
I didn't test the inertia switch for 12v. It just wasn't tripped.
EDIT: Just checked inertia switch and getting 12volts when the key first is turned to ON, then it drops to 6.8 volts and stays there. Still don't know where the fuel pump relay is.
.... EDIT: Just checked inertia switch and getting 12volts when the key first is turned to ON, then it drops to 6.8 volts and stays there. Still don't know where the fuel pump relay is.
I don't see a fuel pump relay in the 2001 F250 Owner's Manual I found at: https://owner.ford.com/tools/account...rd&model=F-250
Seems odd, there should be a fuel pump relay somewhere.
The fuel pump is turned on for a few seconds when the ignition switch is turned to Run to prime the lines, then shut down. When the ignition switch is turned to Start the PCM looks at several other inputs and fires up the fuel pump to run the engine when everything is good to go. With the engine running the voltage at the Inertia Switch should be system voltage or around 13.4v. I added a voltmeter on the dash and tapped the Inertia Switch output lead for the source. The voltage is usually around 13.2-13.5v or when the battery is low can go up around 14.2v when the engine is running.
When do you see the 6.8v? When the engine is running? That would barely be enough to run the fuel pump or not.
For a test you could run a new wire from the battery to the Inertia Switch.
Engine does not run. Engine quit while driving and hasn't started since. I had it towed home.
I put the multimeter on all 3 wires going into the inertia switch. Only one shows any voltage.
key off = 0 volts
key on = momentary 12v, then steady 6.8v after that
when I say 12v that's literally what the meter reads 12.0 volts. Battery at the terminals is currently 12.4v. I just put it on a charger. I think I drained it a little testing on the road side.
key off = 0 volts
key on = momentary 12v, then steady 6.8v after that ....
After selecting Run and getting momentary 12v what is the fuel pressure at the test port on the fuel rail?
With a good fuel pump there should be pressure in the rail, 32+ psi.
It sounds like his pump wiring is working, the voltage will go down until the engine begins cranking and then it will come back up. I would just replace the pump.
The voltage going to 6.8v is strange, it should go to zero or near zero.
If the voltage is going to 6.8v while cranking that is too low for the electronics to work, should be at least 9.5v while cranking.
If the fuel pressure is good at initial turn on the pump does work, but doesn't mean it will hold pressure while running.
We need more info on the fuel pressure.
If the contacts in the relay are burned you might get enough power thru it to prime the rails, but may not allow enough current thru to maintain volume while running.
A test lead from the battery to the Inertia Switch or all the way back to the pump would help a lot.
I think it's probably the pump, but I've read posts from several people that have changed pumps only to have the problem be the relay.
i hear you, and I'm all about troubleshooting before throwing parts at it. The voltage going only to 6.8 is kind of odd but it's definitely not enough to run the pump. test key on engine off voltage and then try cranking it and see what voltage does.
I don't have a fuel pressure gauge but can say the pressure is very low. 30psi should spray. I'm getting a dribble out of the relief valve.
Engine cranks but not even a hint of it going to fire. It just cranks and cranks.
I will test it again when I get home as you suggest. I haven't tried to see what voltage does while cranking. I just checked it in the on position.
Gas tank rubber vent lines, had my bed off the other day to wire wheel and repaint the frame and the hoses that I replaced three years ago were all flaking apart and crumbling. Looks like I'll have to add it to my yearly routine
