Air Bag, disabling
Old Mar 23, 2019 | 12:35 PM
  #31
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Iraa
...meaning one is to take a 25 year old truck in for service to fix a problem which I would like to fix myself and a problem that the service department probably would like for me to fix also.
You are incorrect in your assumption that you cannot repair it yourself. From the information that I provided it indicates that the air bag light in the dash is not working. Is this correct? Does the light come on when you first turn the key to run? Retrieve the fault code and figure out what is wrong. The clockspring was notorious for going bad which you can replace in your driveway. No dealer or service center/shop required.
Old Mar 23, 2019 | 02:23 PM
  #32
Skip1970's Avatar
Skip1970
I would rather die like a real man without a airbag, my motorcycle dont got no lamo seatbelts or airbags.
Old Mar 23, 2019 | 03:38 PM
  #33
Iraa's Avatar
Iraa
I have already replaced the clockspring. The air bag light in the dash does come on and flashes constantly. I will remove the air bag one more time and connect the clockspring to the air bag and then see what code the air bag in the dash is flashing. Thanks
Old Mar 23, 2019 | 05:13 PM
  #34
Iraa's Avatar
Iraa
Replaced air bag. Air bag indicator light in dash is on for the six seconds with key in run position; then, gives a code 12 repeatedly. I have a new battery and good voltage in this truck. This code 12 I assume is signaling low voltage. Don't make sense. Also, chime sounds 5x5.
Old Mar 23, 2019 | 06:33 PM
  #35
My4Fordtrucks
In that case I hope you also don’t wear leather or a helmet. May I suggest only wearing shorts? Just in case you make it through the accident you can be manly while they pick asphalt/ gravel out of you.
Old Mar 23, 2019 | 07:24 PM
  #36
Skip1970's Avatar
Skip1970
haha! been there done that, learned from it. always wear my cycle gear now, have over 80,000 street miles under my belt on a bike. squid b gone.
Old Mar 24, 2019 | 11:58 AM
  #37
Iraa's Avatar
Iraa
Ten amp fuse reinstalled in knee panel fuse box. Now exhibiting code 13 ( Air Bag Circuit Shorted to Ground). Now, what to do -- disarm the bag or try to find where it is grounded which may prove to be quite a task??? Short couldn't be in or around new clockspring as I installed it and don't recall anywhere it may be grounded.
Old Mar 25, 2019 | 03:56 PM
  #38
Iraa's Avatar
Iraa
where is the air bag diagnostic monitor? Iraa
Old Mar 25, 2019 | 07:33 PM
  #39
My4Fordtrucks
Searched “1994 F-150 air bag module location” and a thread on here provided this picture.
Old Mar 25, 2019 | 07:49 PM
  #40
Iraa's Avatar
Iraa
Got all hooked up. Code 13 says short to ground. Found right hand and left hand sensors. No obvious shorts. No drag on battery. Brrrrrrrrrrrr!!!!! All roads pointing toward disabling.
Old Mar 26, 2019 | 07:57 AM
  #41
My4Fordtrucks
There is this thread on the forum with pinpoint tests:
1994 F150- airbag code 13, already replaced clockspring
Old Mar 26, 2019 | 09:00 AM
  #42
Iraa's Avatar
Iraa
I have just printed
1994 F150- airbag code 13, already replaced clockspring and will try and fix my problem. Thanks for all your info given on my prob. Iraa
Old Mar 26, 2019 | 01:31 PM
  #43
Iraa's Avatar
Iraa
Does the Air Bag Diagnostic Monitor control anything other than operation of the air bag on this 1994 Ford, F-150, 5.0L, SWB truck? It appears to have two wiring harness connected.
Old Mar 26, 2019 | 02:06 PM
  #44
rla2005's Avatar
rla2005
Connector C217 is mainly power and C218 is the interface to the Safing sensor, airbag and crash sensors. No other function/control other than the Airbag lamp in the instrument cluster.
Code 13 indicates a short in the Safing sensor/Airbag not the crash sensors. In the event the Air Bag Diagnostic Monitor senses a short to ground in that circuit it will flash out Code 13 and.....blow the internal thermal fuse. If you would repair the shorted circuit then you will see Code 51 flash out (Internal Thermal Fuse open).
With that internal fuse open there is pretty much no way to trigger that bag without opening it up and applying power with jumper leads and a battery.
Old Mar 26, 2019 | 05:18 PM
  #45
Iraa's Avatar
Iraa
Thank you very much for your quick response. It is very helpful information. This info will help to fix my air bag system. Again, Thanks very much. What an education about air bag system on this forum. Iraa
Nightrain
Aug 9, 2006 03:43 PM
ken1mod
Aerostar
Jan 23, 2006 01:52 PM
Pookie's Dad
Jun 18, 2005 07:20 AM
Domino
Feb 10, 2003 10:14 PM
