there should be a tag on the rear diff that tells the ratio. the front is usually one diget off. for instance the rear being 3.55 and front 3.54. if you plan on regearing take into concideration what size tires you plan to run in the future sense you have a 3 speed 4.10's would be a good safe choice with 33's or even 35's maybe.what size engine you running? just remember you must do both gears the same otherwise you cant use 4x4
late
On a dana 44 TBS front, if you go over 3.73 in the front, you have to change the carrier also. (which can be expensive)
I went from a 3.54 front to a 4.09 and got a precision gear power loc carrier at the same time. In the back, you can use the stock open carrier with 4.10 gears but while you've got it out, it's best to toss an EZ-locker in there for another 200 bux. Whatever gear ratio you choose, just remember the front carrier will have to change also if you go big.
stock carrier = 3.73 and under
New carrier = 3.92 and over
I wouldn't go bigger than 35's or 36's with stock axles, so 4.10's will do you fine if you stay on the road mostly. If you want to do some crawling, 5.13 is the largest matched set you can get. You can go up to 5.88 in the back but I think the closest front ratio to that is still not close enough for safe pavement use.
MPH (highway speed) x gear ratio (rear end) x 336 / tire diameter
Gives you engine RPM.
or
If you have a transmission with overdrive...
MPH (highway speed) x gear ratio (rear end) x overdrive ratio (usually about .73-.75) x 336 / tire diameter
Example:
60 (mph) x 3.55 (rear end ratio) x 336 / 31 (diameter in inches) = 2308.
And if you think OD doesn't make much difference:
60 x 3.55 x .75 x 336 / 31 = 1731
The engine RPM should be at or just below your engine's power band 2000-2800 on average for a SB V8. (Some will argue a little less or a little more).
The gearing front and rear should remain very very close. Ford geared the front .01 different in an effort to get the front end to pull just a touch when running in 4WD. Hence, as Kem stated, the 3.54 front and 3.55 rear.
so the .01 in the gears doesn't hurt anything, thats good. I don't know what i habe now, the tag just has a bunch of numbers and letters, nothing coming out to a gear ratio. I'll keep huniting, maybe the vin will do the trick.
Boy am i red in the face, thanks for pointing that out, I updated my sig very late lastnight (early mornin). Us army guys aren't always as literate as we'd like to be at 4 am. LOL
Originally posted by Doorgunner808 Boy am i red in the face, thanks for pointing that out, I updated my sig very late lastnight (early mornin). Us army guys aren't always as literate as we'd like to be at 4 am. LOL
No prob, didn't think u wanted everyone to think u had a bonco!!!
I don't think anyone is really good at that time of night, not even me, and thats when I work-lol
