cam gear ratio?
Old Aug 12, 2013 | 08:41 PM
southtexasidi's Avatar
southtexasidi
cam gear ratio?
anyone know what the ratio for the cam gear is in relation to engine rpm? I need to know the cam gear/engine speed ratio to hook up my aftermarket tach. any help is appriciated.
Old Aug 12, 2013 | 10:05 PM
hairyboxnoogle's Avatar
hairyboxnoogle
cam turns half speed of the crank
Old Aug 13, 2013 | 09:01 AM
southtexasidi
I appreciate it
Old Aug 13, 2013 | 09:31 AM
whiteboyslo's Avatar
whiteboyslo
Kinda weird. Do they intend the tach to work on 2-strokes as well or something? Any 4-stroke is going to have a 2:1 crank to cam ratio (two piston cycles per valve cycle)
Mike
Old Aug 13, 2013 | 09:37 AM
hairyboxnoogle
Mike
Pretty much summed up what i was thinking as well
Old Aug 13, 2013 | 03:00 PM
southtexasidi
It has to do with the tach calibration. The tach can
Be calibrated by the number of teeth on the gear used to read off of, like the cam gear or flywheel. If used on the flywheel, you would calibrate using the exact number of teeth on the flywheel, whereas with the cam gear, Since it's a 2:1 ratio I will use half the number of teeth in the calibration equation. The equation to use is written down at home I can't remember it now, instill need to read up on all that
Old Aug 13, 2013 | 09:32 PM
Macrobb's Avatar
Macrobb
Yup, divide the number of pulses by 53 if you use the stock VRS(or replace it with something else in the same spot).
What tach are you using? When I was looking around, I couldn't find anything for a reasonable price and ended up making my own with a microcontroller(see topic).
Old Aug 13, 2013 | 09:40 PM
southtexasidi
its an isspro r13000 series tach, im planning on using the factory tach sensor on the gear cover. im assuming the cam gear has 53 teeth?
Old Aug 13, 2013 | 10:15 PM
Macrobb's Avatar
Macrobb
106 teeth, at 1/2 rev per engine revolution.
isspro r13000 doesn't seem to have a tach in their lineup that I could find through google; got a link?
Old Aug 13, 2013 | 10:35 PM
southtexasidi
Whoops sorry r65000 series. They match the 13000 gauges which is what I have in the truck already, so I bought the r65000 speedo and tach to match
kc8yhk
33
Aug 25, 2018 10:58 PM
Dutchbuilder
Jun 27, 2015 09:52 PM
68cabby
13
Nov 5, 2012 07:11 PM
BroncoII85
Bronco II
Jan 31, 2005 09:06 PM
dj8667
Jan 27, 2005 05:54 PM
