As noted in another thread...I just bought a 2012 F250 with the 6.2 L gasoline engine.
The owner insisted that that oil was new, but I typically change the oil whenever I buy a vehicle...my OCD kicks in.
I'm looking to replace the air filter as well...don't know when that was last done...and probably some fluids. PS, brake, differentials...I'll likely get the transmission serviced before the summer towing season begins.
I'm thinking I should probably change the fuel filter as well, but where is it?
Anything else I should look at?
I agree with all fluids. I got burned on my last truck, guy said he just put amsol syn rear diff fluid in. I didn’t drain it right away like I normally did and after 30,000 miles or water mixed in with the fluid that I didn’t know about I paid for it to the tune of $2,000 for an axle rebuild. You are on the correct track.
OK...the wife's RAV4 also has the in-tank fuel filter, so I guess that's all right.
Anyone ever install a POST-filter, FWIW....would that even be useful?
Going through the PO's maintenance records...lots of Mr. Lube type of receipts for oil changes and stuff like that....some from the Dealer. Looks like tranny was serviced about 30,000km ago...I'll still do it anyway for my own peace-of-mind.
so you know.. the 2011 to 2018 transmission has a thermostat in the transmission.....
so you can only drain out half of the fluid with a filter change... so in 2 years do it again..
even most Ford dealers do not have the heated transmission fluid exchange machine.... for a full flush at one time...
these Ford trucks are NOT your fathers Oldsmobile ...
I've only heard of it happening on one motor so it's not a known problem. Just be straight on the plug and it will take a little pull to break them loose.
Denny
Thank you for the insight you may have just given me enough confidence to try it
Hello I was wondering if anyone had any links to epa compliant catlytic converters for 2012 ford 6.2l i bought it at 80k miles and i just crossed over 100k i went under it and realized the cats have been cut out of it, i currently only get 8mpg and would like it to raise even a little
Putting the cats back in won't help your mileage, if anything since it is another restriction in the exhaust it will hurt you.
Might want to look into making a new thread on this since it's a separate subject, but unless you need them for inspections there's no reason to put them back in.
Make a new thread, give us more info about what's going on with your truck, gears, trans, etc, and then we can give you some pointers. That said, if you're getting 8mpg around town that's probably close to normal, if you're getting 8 on the highway either you're driving 90 everywhere or you've got some issues going on that cats aren't gonna help.
Its just running super rich and low gas mileage, I also put a flow master exhaust in it and now it acts a little weird while shifting
Someone must of fooled the computer if its not throwing a CEL. Putting the cats back and ensuring the o2 sensors are operating correctly and not being fooled or gapped WILL help your fuel mileage as it will lean it out and run more efficiently. The cat back exhaust will free up the flow a bit but its not going to change the fuel map or help mileage, it actually can hurt your mileage under load as it actually trades low end torque for a few more hp on the top end.
