Sponsored by: Auxito
Torque specs for oil sensor switch/sending unit
Old Mar 12, 2019 | 08:22 PM
goose4wind's Avatar
goose4wind
I have a 2001 F-150 XLT 5.4 L Triton V8 4X4. I have oil leaking what appears to be around the oil sending unit. It is located next to the oil filter, which is near the drivers side front tire. I found the right deep well socket (21mm) to remove the switch. Hopefully I can get a ratchet in there to get a hold of it to remove it. It looks awfully tight. Does anyone know the torque setting when I install the new switch? And is the thread lock that's already on the new switches threads enough to keep it from leaking, or should I wrap some additional teflon tape around the threads? Thanks, Goose
Old Mar 13, 2019 | 09:59 AM
alloro's Avatar
alloro
107-143 in. lbs. is the torque spec, but as long as it's snug the thread seal that comes on it is enough to prevent leaks.
Old Mar 13, 2019 | 11:25 AM
goose4wind's Avatar
goose4wind
Thanks alloro for the information !! goose
cjensen68
3.7, 3.5 and 3.0 Duratec V6
Jan 10, 2019 12:29 AM
Nohfd53
Oct 7, 2011 03:18 PM
digger658
Jul 26, 2007 12:03 PM
randle_ford
Sep 9, 2005 10:19 PM
mike420
1997 - 2003 F150
Mar 2, 2004 07:58 PM
