Sponsored by: Auxito
Front diff help
Old Mar 11, 2019 | 07:31 PM
Max Cottongim's Avatar
Max Cottongim
Front diff help
2002 f150 lariat fx4 5.4 220,000 I put the truck on 4 jack stands because I thought something was wrong with the 4wd. The front passenger tire was ok, the front driver tire seemed to turn very slowly and then stopped. So only three wheels are spinning in 4L and 4H. The only thing I found was a thin black plastic hose coming from a reservoir on the back of the battery mount had been disconnected. Here are pics of the type of truck I have
Old Mar 11, 2019 | 07:48 PM
ford390gashog's Avatar
ford390gashog
Was the truck running? Sounds normal if the vacuum actuator is engaged.
Old Mar 11, 2019 | 08:08 PM
Max Cottongim
yes the truck was running, and in 4L. Is it normal for it to only spin 3 wheels?
Old Mar 11, 2019 | 09:35 PM
ford390gashog
If you have a sticking brake caliper it will stop one wheel. It is a open differential so the wheel with the least resistance will spin. Check your brakes.
Old Mar 12, 2019 | 10:04 AM
alloro's Avatar
alloro
Yes like ford390gashog said, it's an open differential up front so if the brake is grabbing slightly more on one side then it's less likely to turn.
Old Mar 12, 2019 | 04:04 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
. . . what they said ^^^^^^
. . . and any bit of extra friction, could even be different ages of lubricant in CV joints etc.
You can check by (carefully and at low rotational speed) attempting to stop the spinning one to see how easy it is to overcome. It should be pretty easy.
96hauler
All Things Towing
Oct 19, 2017 08:59 PM
Mattb60
Sep 9, 2013 12:29 PM
hivoltj
Sep 10, 2012 10:03 AM
Rat77
53
May 30, 2012 05:00 PM
gddyup
Jun 20, 2010 05:41 PM
