Horn issue :(
Old Mar 10, 2019 | 06:49 PM
robski_1970's Avatar
robski_1970
Does the horn work when the H lead of the relay is connected directly to ground? (bypassing the wire in the column and horn button)
Old Mar 10, 2019 | 06:58 PM
matthewq4b's Avatar
matthewq4b
He is cooking the relays. The only way that could be happening is if it was connected it as Described in post 10. He says the horn/s are working if power is fed directly to them.
Old Mar 10, 2019 | 07:23 PM
robski_1970
If youre frying relays, might be a problem with the voltage regulator.
Old Mar 10, 2019 | 10:14 PM
matthewq4b's Avatar
matthewq4b
Go back and read his initial and subsequent posts. The only way to cook the relay would be to over volt it. And by the time voltage was high enough to do that you would cook every light bulb in the truck. And regardless the horn relay is fed from the Bat + it is just tapped at the VR. The VR could go completely sideways and it would not affect the horn relay doubly so since the battery would act as a buffer.
Now if the relay was not tapped on to the correct terminal at the VR that could pose some issues.
InfidelReaper
May 10, 2013 03:36 AM
Snapper3
Nov 9, 2012 03:42 PM
Joeseph
Jul 18, 2012 02:01 AM
mcne
Electrical Systems/Wiring
Oct 13, 2005 09:37 PM
lazerus
Sep 26, 2004 07:51 PM
