Master cylinder
Old Mar 7, 2019 | 02:26 PM
Phil59's Avatar
Phil59
Master cylinder
What is the best mc for a 1959 f100 with standered drum drum brakes. Looking for two pot setup.
Old Mar 8, 2019 | 09:17 AM
Maltman's Avatar
Maltman
Summit has a kit I bought a while ago-still need to install. Seems good quality.
Old Nov 24, 2019 | 06:58 PM
bruman's Avatar
bruman
I've read somewhere on this site that a 1979 Ford trk master is a good choice. Good that you're going with a dual piston master!!!!
Old Nov 24, 2019 | 07:59 PM
Tedster9's Avatar
Tedster9
Since there are drums on both axles, this won't work correctly? He wants a dual master cylinder for a drum system, something like a '68 Mustang, maybe.
Old Nov 24, 2019 | 08:28 PM
JohnNewb's Avatar
JohnNewb
Someone must make conversion kits. You would need to replumb the tubing to separate the front and back.
Old Nov 25, 2019 | 04:56 AM
Walston's Avatar
Walston
You have to change the mounting from 4 bolts to two, or make a bracket.
https://shop.advanceautoparts.com/p/...aster+cylinder
Old Dec 1, 2019 | 06:15 PM
manglass's Avatar
manglass
I used an EC-412 adapter from here: Engineered Components, Inc. - Your One Stop Brake Shop! along with the master cylinder from a 1970 Ford Mustang with manual drum brakes.
Lou Manglass
Resurrected 56 F100
Aug 23, 2015 07:49 AM
azfordf100man
15
Sep 23, 2007 08:00 PM
jenkinsj
Sep 4, 2005 04:12 AM
58_f100_4x4
May 20, 2002 08:09 PM
