RPM’s
Old Mar 6, 2019 | 05:59 PM
slabhunter's Avatar
slabhunter
RPM’s
I purchased a Bosch tachometer from Jets to put on my 61 F100. I know you get what you pay for so this could be the case with this, that being said how many RPM’s (approximately) should my 223cu, 3 on the tree be turning at say 55 mph?
Old Mar 6, 2019 | 06:30 PM
john jamieson's Avatar
john jamieson
What gears are in the rear?
Old Mar 6, 2019 | 06:49 PM
85e150's Avatar
85e150
With a 29 inch tire and your 1:1 3rd gear, at 55 mph you will turn the rpms shown by each possible rear axle ratio:
3.25 = 2071
3.50 = 2230
3.70 = 2358
3.89 = 2479
4.10 = 2613
3.50 might be the most common gear.
Your warranty/data plate has the VIN, trans, color, axle etc codes on it. Your differential came with a sheet metal tag on one of the studs, about the "5 o'clock" position. Big IF regarding either of those still being there, and another big IF regarding you axle being OEM.
Old Mar 6, 2019 | 06:55 PM
slabhunter's Avatar
slabhunter
I don’t know yet what gears are in it but I was turning about 1800 RPM’s at about 55 mph. It sounds like it’s turning 5000!
Old Mar 6, 2019 | 07:07 PM
85e150's Avatar
85e150
Does the tach have a switch for 4/6/8 cylinders?
3.0 gears would rev 1912, but then we don't know your tire size, axle ratio etc.
To turn 5000 rpm at 55, you would need 7.85 gears, so I think we can count that out.
Seriously, at 1800 rpm at that speed your motor should hum and sound very happy.
Old Mar 6, 2019 | 08:30 PM
The Masked Rider's Avatar
The Masked Rider
I'd also check the switch location as mentioned. I think most tacks out of the box, are set for V8.
Old Mar 7, 2019 | 10:32 AM
slabhunter's Avatar
slabhunter
Thanks for everybody’s reply! First lesson, read the directions! Found the switch on the back of the tach, set on 6 and tried it again. I was turning 2200 RPM at 55 mph on speedometer app on my phone (speedometer doesn’t do anything but bounce around). I also took off the aftermarket breather and put the original oil bath breather back on it sounds a lot better.
Thanks for the info.
Old Mar 8, 2019 | 08:11 PM
RangerMercMan's Avatar
RangerMercMan
There are some smart people here. I forgot about the 4/6/8 switch. In regards to your bouncing speedo take the cable out and grease it. Bye Bye bouncy bouncy!
u8mylnch
40
May 15, 2015 02:48 PM
br1987
Mar 3, 2009 07:53 AM
Mr Mayo
22
Aug 22, 2008 10:30 PM
asmith6
27
Nov 11, 2007 03:19 PM
78'fordman
Sep 4, 2003 10:16 AM
