2018 Steering Box Play
Old Mar 20, 2019 | 11:33 AM
  #31
Imadentguy's Avatar
Imadentguy
​​​​​​AAAAAAAAAAND NO MORE RATTLE IN THE STEERING WHEEL AND FLOORBOARD / PEDALS! Dealership did not show a new part number for the upper fastener.... of course no bulk bolts in stock. Went to ace hardware and found an allen head bolt, and a stainless lock washer. Little blue lock tite for the threads. Ran home and installed it, and drove to work. Pulling out the driveway i immediately noticed that my steering was much smoother yet “tighter”. Off the bat i could tell it was GTG. So my advice to anyone having issues with a rattle feeling in the steering wheel and floor board, replace the lower intermediate shaft. Its cheap enough that its worth a shot.
Old Mar 20, 2019 | 11:47 AM
  #32
Imadentguy's Avatar
Imadentguy
I believe the needle bearings were bad in the old shaft. The bearings were notchy and i believe the rattle was the result of out of tolerance needle bearings. I had not realized how bad my steering had degraded, until i replced that shaft.
Old Mar 20, 2019 | 12:29 PM
  #33
bowhunter211's Avatar
bowhunter211
Awesome! I will be ordering the shaft tonight. I will let you guys know if it fixes mine also. Thank you very much.
Old Mar 20, 2019 | 12:37 PM
  #34
Imadentguy's Avatar
Imadentguy
Cool. Make sure you report back. I will add that my local dealership still showed national backorder. You may need to try an online vender if you cant get it locally.
Old Mar 20, 2019 | 01:02 PM
  #35
jlalanas's Avatar
jlalanas
Do you have the 6.2gas or the 6.7D?
Looking at your pics the steering shaft looks like it's easily accessed, if I recall what my engine bay looks like I think there is a bunch of stuff that covers that area. Anyone with the diesel take a look at this yet?
Old Mar 20, 2019 | 01:10 PM
  #36
Imadentguy's Avatar
Imadentguy
I have the 6.2
Old Mar 22, 2019 | 02:10 PM
  #37
brentadams646's Avatar
brentadams646
Holy ****, I can't even see my steering shaft from the topside with all the junk under the hood with the 6.7L lol
Old Mar 23, 2019 | 01:58 PM
  #38
Bigblock17's Avatar
Bigblock17
My F250 6.7 was built on 10/17 and has the updated lower steering shaft from the factory. I found that the grommet going through the firewall has some minor slop.
Old Mar 23, 2019 | 10:53 PM
  #39
Imadentguy's Avatar
Imadentguy
Did you do something to fix it? Mine still has slop at the firewall, but every other 250 ive looked at has had some measurable movement to different degrees. Im so happy i figured out that my lower shaft was bad. I now enjoy driving my truck again.
Old Mar 24, 2019 | 02:00 PM
  #40
Bigblock17's Avatar
Bigblock17
At this point it looks like it's more trouble than it's worth. Replacement is really the only fix. When it get's annoying I'll be more motivated to do this. Right now I hardly feel it.
Old Dec 3, 2019 | 12:52 PM
  #41
Randy Tran's Avatar
Randy Tran
Hello, i have a similar problem my acceleration pedal i notice it when i have my steering wheel steering to the right as i am making a small curve. it’ll make all kinda pulsing vibration in my acceleration pedal like it’s connected to my shocks. I took it to the dealership and sure enough they didn’t feel jack **** as soon as i picked up my truck from the dealership and leaving i Felt all the vibration in my acceleration pedal. Is the lower shaft an ideal to fixing this?
Old Jan 13, 2020 | 12:05 PM
  #42
Torqd1's Avatar
Torqd1
Has anyone else replace the lower shaft on the 6.7? I'm seeing the part # as Shaft Assembly - Ford (HC3Z-3B676-C). Is this the "upgraded" shaft or the same POS OEM one? Thanks!
Old Jan 27, 2020 | 05:41 PM
  #43
Lalod89's Avatar
Lalod89
Is this the same
Sure!
Is the same as yours didnt find the part ending with b
Old Jul 16, 2023 | 12:03 AM
  #44
hobbie1's Avatar
hobbie1
Just saw this thread while doing some searching.
On my 2018 6.7 I get this odd light feeling in the steering.
It feels like something is loose yet the steering wheel is not loose. I notice more so when going do a freeway that is less than perfect.
Tires are wearing perfect and the truck tracks perfect.
It feels like something is loose yet appears that nothing is loose.
I have all Fox 2.0 shocks and the Fox adjustable ATS.
78000 miles
soonerstroker
Aug 30, 2025 02:55 PM
throwdown
Oct 5, 2011 04:43 PM
99'FordExplorer
Jul 26, 2006 08:00 PM
Greatsaves28
16
May 24, 2005 10:57 PM
