Skid plates
Old Mar 7, 2019 | 06:59 PM
ForCal's Avatar
ForCal
Originally Posted by mtl-biker
Hi
In the rush when i place my order i said no to the FX4 package.
But forgot to add the Skid plates did happens to somebody??
It is a way to ordered and the part number also?
Thanks
Mario
Is it too late to correct the order? It's only $100 msrp installed if you add it to the build.
Old Mar 7, 2019 | 07:22 PM
MBaldo's Avatar
MBaldo
Does anyone have a link where I can order the OEM set of Skid Plates for a 2019 Ford F350 Lariat ... 6'-9" Bed? For some reason, I can't find where to purchase them.
Old Mar 7, 2019 | 08:32 PM
ShadowGrey's Avatar
ShadowGrey
No skid plates on mine. Useless weight as it probably will not do anything more than farm/field roads when hunting.
Old Mar 8, 2019 | 05:46 AM
mtl-biker's Avatar
mtl-biker
Originally Posted by DeputyDiesel
You can change your order if you haven’t received your VIN yet. Otherwise you can order the skid plates from ford and install them yourself
Hi
It will delivered it to me monday to late lolll
Mario
Old Mar 8, 2019 | 05:50 AM
mtl-biker's Avatar
mtl-biker
Hi
Check that probably you could send it email to confirm it
https://www.powerstrokeplus.com/oem-...IFJlc3VsdHM%3D
Mario
Old Mar 8, 2019 | 08:04 AM
MBaldo's Avatar
MBaldo
Hi
Mario
Thanks for the link. Is that the only skid plate that comes on the FX4 Package? Is there other plates for Transmission and Transfer Case?
Old Mar 8, 2019 | 09:01 AM
67L48's Avatar
67L48
Only two: transfer case and fuel tank. The transfer case skid plate is about $30 online (before shipping) and I don't believe it comes with bolts. The fuel tank skid plate is quite expensive and runs $130 - $200 online (before shipping and installation bolts).
Also, I think a small child could easily install the transfer case plate. The fuel tank plate, however, isn't easy to install. Above, people mentioned that you don't have to drop the fuel tank to install it. I read somewhere else that the mounting locations are so tight that it's nearly impossible to fasten the hardware without dropping the tank at least a few inches. I don't have any personal experience, so I don't know what the real story is ... other than, no matter how you slice it, installing the fuel tank skid plate sounds like a real knuckle buster.
If you value those two skid plates, the $90-ish for the two are maybe the best deal/value on the entire factory options list.
Good luck.
Old Mar 8, 2019 | 09:08 AM
Mkos1980's Avatar
Mkos1980
I was driving across a pretty snow covered abandoned parking lot once and a huge piece of rebar was sticking up. didn't see it but my skid plate bent it over vs hitting my aluminum oil pan on my 2500HD 6.0 Gasser. 100 bucks was well worth it for me.
Old Mar 8, 2019 | 09:27 AM
1956Fatfenders's Avatar
1956Fatfenders
Originally Posted by ATC_F350
Has anyone ever actually had a skid plate hit? I've got a soon to be 19 year old SD and have driven in everything but rock crawling, never needed a skid plate.
I've had skids plates on multiple vehicles and never had to use them (as far as I know). I'm more concerned about kicking up a chunk of metal or whatever on the highway and damaging the tank or transfer case. For me, I look at it more as insurance than something I'll use every day. A punctured fuel tank while on vacation would certainly be a pain in the ars.
Old Mar 8, 2019 | 10:03 AM
mtl-biker's Avatar
mtl-biker
Transfer case also, dont forgot to ask for the bolts and brackets that required for the install!!!
mario
Old Mar 8, 2019 | 09:46 PM
brandontolentino's Avatar
brandontolentino
Here's the part numbers I used for my transfer case skid on my 17 CCSB:
HC3Z-7E063-A
Skid Plate
$27.91
Tax : California State Tax (8.00%)
$27.91
-W718878-S439
Bolt And Washer Assembly - Hex.Head
$2.68
$10.72
-W719567-S439
Nut
$1.25
$5.00
PaleRider01
Jun 4, 2019 11:45 PM
Straightgrain
Oct 2, 2018 08:24 PM
wb6anp
Apr 21, 2017 09:40 PM
Dom165
Jan 26, 2016 12:12 PM
joed_6
Feb 22, 2003 07:10 PM
