Skid plates
Old Mar 6, 2019 | 11:19 AM
mtl-biker's Avatar
mtl-biker
Skid plates
Hi
In the rush when i place my order i said no to the FX4 package.
But forgot to add the Skid plates did happens to somebody??
It is a way to ordered and the part number also?
Thanks
Mario
Old Mar 6, 2019 | 02:10 PM
DeputyDiesel's Avatar
DeputyDiesel
You can change your order if you haven’t received your VIN yet. Otherwise you can order the skid plates from ford and install them yourself
Old Mar 6, 2019 | 02:19 PM
1956Fatfenders's Avatar
1956Fatfenders
While I did not get the FX4 package either as I bought off the dealer lot, I did purchase a fuel tank skid plate from someone on this forum that had upgraded to a larger tank. For the transfer case, someone had a thread stating parts needed, so I purchased that. Yes you end up paying more, but at least you don't end up with "Rancho" shocks...
This is what I ordered from TASCA for the transfer case:
HC3Z-7E063-A Skid Plate $26.98 (1)
W718878-S439 Bolt And Washer Assembly - Hex.Head $10.72 (For 4)
W719567-S439 Nut $5.00 (For 4)
Total w/shipping to WI was $65.27.
Old Mar 6, 2019 | 04:29 PM
wb6anp's Avatar
wb6anp
Ill have to lookinto thay skid plate, my dealer quoted me $300 for t case skid plate.
Old Mar 6, 2019 | 04:35 PM
ytechie's Avatar
ytechie
I have to figure out how to sell mine. I’m in Wisconsin.
Old Mar 6, 2019 | 05:35 PM
KEVPOPPAPUMP's Avatar
KEVPOPPAPUMP
Skid plate was fairly cheap and simple to throw on. The fuel tank skid plate wasn’t cheap and appears you’ll have to drop the tank to install it so kind of a pain, so I passed on that.
Old Mar 6, 2019 | 06:00 PM
bigspeedy626's Avatar
bigspeedy626
You don't need to drop the fuel tank for the skid plate. Just make sure you get the correct hardware for it. For instance the correct size "U" nut for the frame.
Old Mar 6, 2019 | 06:25 PM
KEVPOPPAPUMP
Talking
Good to know not having to drop the tank. The parts diagram is a bit confusing to look at. Maybe somebody will post all the necessary part numbers like they did for the transfer case skid plate
Old Mar 6, 2019 | 07:20 PM
bigspeedy626
For my install, I just went to home depot for the bolts and washers. Oreilly or any auto parts store should have the "U" nuts.
Old Mar 7, 2019 | 05:31 AM
mtl-biker's Avatar
mtl-biker
Thanks to all i just need the part number for the tank
Mario
Old Mar 7, 2019 | 06:17 AM
mtl-biker's Avatar
mtl-biker
I think its the good part number???
https://www.powerstrokeplus.com/oem-...IFJlc3VsdHM%3D
Can someone confirm it
Thanks
Mario
Old Mar 7, 2019 | 11:53 AM
bigspeedy626
I believe that's the right part #. But you still need to buy 3 other brackets not included with the skid plate. Skid plate comes with 1 bracket welded on.
Old Mar 7, 2019 | 11:59 AM
mtl-biker's Avatar
mtl-biker
Yes i saw that also thanks
Mario
Old Mar 7, 2019 | 05:07 PM
ATC_F350's Avatar
ATC_F350
Has anyone ever actually had a skid plate hit? I've got a soon to be 19 year old SD and have driven in everything but rock crawling, never needed a skid plate.
Old Mar 7, 2019 | 05:30 PM
67L48's Avatar
67L48
Once when hunting with my 2005 F150 -- very rocky forest service road and I heard it. Bent the lip of it just a tiny bit ... enough that at resonant frequencies, it would rattle. It literally took me years to figure it out. I lived with it for a very long time, thinking it was the sound of my transmission slowly dying. Finally took it into a transmission shop and they could find no issue. There are about 78 different causes for these rattles from loose exhaust hangers, to heat shields, to rocks trapped in crevices, and on and on and on. I think it was 5-6 years living with the noise until I finally snapped. Spent about 2 hours under my truck with wrenches and hammers. Finally decided that I could replicate the sound with a hammer on one of the skid plates. Yanked it off and immediately saw the very small bend in the lip. Tossed it in the trash.
I ordered a new SD. I didn't order skid plates. It wasn't to save money. ;-)
