Sponsored by: Real Truck
4.88 help
Old Mar 5, 2019 | 08:58 PM
Josh Hein's Avatar
Josh Hein
4.88 help
I have a 2002 f250 5.4 6inch lift and 315 75 r16 I just had 4.88 put in front and rear buy a local shop from 3.73 . The problem I'm having is now when I get to 75mph on the speedometer (80MPH ON GPS )it kinda jerks and such and wont go any faster didnt have this problem with the 3.73 feels like I might be hitting the speed limiter? Ideas
Old Mar 5, 2019 | 09:08 PM
Just Strokin's Avatar
Just Strokin
Did you check the rpm with the 4.88 gears? you might be on the rev limiter??
ford390gashog's Avatar
ford390gashog
Well we need some more. Is the truck tuned and adjusted for gears and tires? Was this a previous fleet truck? Were you able to go above 80mph previously?
Old Mar 5, 2019 | 09:10 PM
Josh Hein's Avatar
Josh Hein
I was at 26 or 2800 rpm in OD
Old Mar 5, 2019 | 09:12 PM
Josh Hein's Avatar
Josh Hein
not tuned or recalibrated for tires or gears and yes could do 90 easy with the 3.73 also not a fleet truck I was under the assumption that it didnt need adjusted for the gears
Old Mar 5, 2019 | 09:38 PM
00t444e's Avatar
00t444e
The speed sensor is in the rear axle so gear ratio has no effect on the speedometer only tire size does.
Old Mar 5, 2019 | 09:44 PM
Josh Hein's Avatar
Josh Hein
Well with the 3.73 the speedometer was 1mph off with the 315 75 tires now with the 4.88 its 3 to 5 mph off and I cant go over 80 mph though with the 3.73 i could get the truck up to 90 mph never tried to go faster then that
Old Mar 5, 2019 | 09:46 PM
00t444e's Avatar
00t444e
However after doing some math 2700 rpm with stock size tires (32") and 3.73 gears in O/D would put you at 97 MPH which is right at where the speed limiter is from the factory. With 4.88 gears at 2700 RPM you would be at 74 MPH which is where it is cutting out on you, so the speed limiter might be based on your RPMs in overdrive rather than on the speed sensor, just a thought.
Old Mar 5, 2019 | 09:50 PM
Josh Hein's Avatar
Josh Hein
I was wondering about that also . So do you think I should buy a tuner and turn off the speed limiter ?
Old Mar 6, 2019 | 08:28 PM
SuperDutyScaler's Avatar
SuperDutyScaler
No you need a tuner to adjust for the gear and tire height difference. Or a Ford dealer might be able to adjust that with their software
Old Mar 6, 2019 | 08:30 PM
SuperDutyScaler
So how do you like the 5.4/35's/4.88 combo?
I installed 35's on my 5.4 (i have 4.30 gears) and I HATED it. Didnt feel it had the "grunt" anymore....was gonna swap in 4.88 but my buddy gave me the same amount of cash i just paid for the new tires so i sold them to him. Now i want another set of 35's but I'll defiently be doing 4.88 that same week LOL
Old Mar 7, 2019 | 05:39 AM
Ron94150's Avatar
Ron94150
While I don't really know about your year and transmission, my '16 shifted funny when I regeared to 4.88's. After programming the computer for the gears, everything was fine. Try turning OD off and see if it cuts off or goes all the way to redline. I don't remember the exact speeds because it's been 20 years, but I had a 94 Dodge Ram that cut off around 100. But you could lock out OD and it would redline 3rd gear somewhere around 112.
jonathan.e.green
17
Sep 11, 2015 12:18 PM
jg96powerstroker
Jan 29, 2011 02:36 PM
HornedFrogHooah
Feb 11, 2010 10:57 PM
starmilt
104
Dec 31, 2008 02:09 AM
97Handshaker
1997 - 2003 F150
May 2, 2006 10:08 AM
