Sponsored by: Auxito
4.6 5-speed question
Old Apr 24, 2006 | 07:39 PM
97Handshaker's Avatar
97Handshaker
What is your speed at 2K RPM's? My GPS says that im running around 65 MPH! Is this correct? I have 3.55 gears and 33 inch tires. shouldnt my RPM's be lower? Do i have 4.10 gears or something? Could I run 35's to lower my RPM's?
Old Apr 25, 2006 | 12:31 AM
fbodyfan's Avatar
fbodyfan
I don't have a 5 speed, but with 33's and 3.55 gears, you should be going at least 75 at 2k.
Old Apr 25, 2006 | 01:34 AM
Bdox's Avatar
Bdox
Yeah, you should double check the reading you are getting from the gps. What does your speedometer say?
And yes, larger diameter tires will lower your rpm for a given speed.
Old Apr 25, 2006 | 11:53 AM
skilife17's Avatar
skilife17
I don't have a 5-speed, w/ stock tires and 3.55s I'm at 2k rpm I'm doing 70.
Old Apr 25, 2006 | 06:01 PM
97Handshaker
My speedo reads 60 MPH. It reads slower because of the larger tires. I know my GPS is somewhat correct because i have to add about 5 mph to my speedo and add about 5% to my mileage due to the 5% increase in tire size. My mom drove beside me on the highway and her tahoe read 65 MPH. Are the 5-speeds geared lower?
Old Apr 30, 2006 | 10:43 PM
charlesh's Avatar
charlesh
Hello,
Sorry it took me a while to respond. I have a 2003 4.6 4x4 3.55 LS with the stock 16 inch tires (265 70's if I remember correctly with 35 pounds of air) 5 speed. I put the tac directly on 2k and the speedo read 62 MPH exactly.
Hope this helps.
Chip
Old Apr 30, 2006 | 11:05 PM
85e150's Avatar
85e150
Check your axle ratio. Should be a tag on it. Or in the VIN.
Find out your 5th gear ratio. .78? .80? I'm not sure.
Check the loaded radius of your tires and double it for the height.
Go here and enter the info and see what you should be running for any given rpm.
http://www.novak-adapt.com/knowledge/gearing.htm
Scroll down to the third place to enter info, under "MPH".
Old Apr 30, 2006 | 11:14 PM
LxMan1's Avatar
LxMan1
The 5-speed has a .80 OD ratio.
Old May 1, 2006 | 12:01 AM
BrianA's Avatar
BrianA
I used to have a 2000 with 3.55 rear end and 5 speed.
In OD (5th gear) it was 32 rpm / mph.
So 65 mph X 32 rpm = 2080 rpm.
About what you are seeing.
Sounds right to me.
FWIW, 2K rpm is not really high rpm. You can run there (and higher) with no ill effect.
At least I did, for 170,000 miles before I sold the truck.
Drive on!
Old May 1, 2006 | 04:29 AM
bigdaddyII's Avatar
bigdaddyII
I wouldnt know, I am too cheap to buy an automatic, power windows and locks, or a tach. much less GPS.
Old May 1, 2006 | 11:53 PM
85e150's Avatar
85e150
2000 rpm, 3.55's, 33 inch tires, .80 OD = 69.17 MPH
See the link I posted before.....
Old May 2, 2006 | 10:08 AM
TennesseeGuy's Avatar
TennesseeGuy
Well, i have 295-45-18's i think they measure about 29.5 in. or so, and at 2k rpm's, im runnin about 55-57. so, im gonna go out on a limb and say that mine is off by a little bit. mine is a 98 5-speed 4.6
