Started running real rough on way home from work. Limped home, missing, rough idle. Codes are p0300 plus misfires on 2,3, and 4. Sounds bad, runs bad, I don't see anything obvious. Thanks in advance for any suggestions.
In this case the 300 code is important.
Random misfires detected. It registered 3 out of 4 cylinders on the passenger side. SAME BANK. 1
Blown heater/leaking hose?
Radiator leak etc.
Moisture getting into the plug wells!.
You have to inspect closer to see what has happened.
There has to be a reason.
Good luck.
Thanks for the replies. No leaks. I wish that was the problem. Removed passenger side valve cover. Timing chain is off the cam sprocket. I don't have the timing chain cover off yet, but guessing the tensioner guide broke. My question is, with this being an interference motor, does the head require work for sure?
Thanks
