1978 F150 build
Old Mar 3, 2019 | 01:26 PM
Res1cue Murf's Avatar
Res1cue Murf
1978 F150 build
New user so please take it easy on me - Im sure my questions are elementary to some.
I recently inherited my dad's 1978 F150 and will begin build this spring. Im learning as I go but have basic knowledge of the truck - which brings me here.
General specs are: 351M engine, 4WD, manual unsynchronized 4 speed transmission (1st gear is "granny" gear"), short bed. What am I missing?
The rig sat in a barn for 10+ years. New battery and it started right up, even passed emissions with no problems. That being said, there are some obvious items that need TLC. Drives better than expected but I notice some issues that seem "off". Idles high most notably while driving. Ive got new fuel pump and filter - although LMC filter for this make/model threads directly into carb. Existing filter is in-line canister. Carb is aftermarket Holley 4brl.
1st Question - will fuel filter and pump address idle issue?
2nd question - will replacing larger bore in-line filter with smaller bore carb-threaded filter have any performance affect?
Thanks in advance! I look forward to getting this project up and moving with some help from this group!!
Old Mar 3, 2019 | 02:03 PM
meangreen92's Avatar
meangreen92
The fuel filter and pump will not address the fast idle. There is an adjustment screw for the idle, and also there are choke parts on the other side of the carb which can cause a high idle.
Do you have pics of the two filters? If it's not too much smaller, then it should be OK. But if it's too small, you could end up starving for fuel.
And welcome to FTE!
Old Mar 4, 2019 | 11:16 AM
CelticOne's Avatar
CelticOne
Regular User
Welcome to FTE and we would love to see pictures of your truck!
If it has been sitting for 10+ years it is definitely in need of a carb rebuild. I would start there. You can buy a kit fairly cheaply.
Old Mar 4, 2019 | 12:19 PM
Meridian_Mike's Avatar
Meridian_Mike
Yep.... we need some pics.... pics are GOOD....
LOTS of pics!
Mike
jgavac
Dec 28, 2017 09:13 PM
akmikek
24
Apr 14, 2010 11:16 PM
jrt103
Jan 1, 2009 05:26 AM
lebelly
Sep 4, 2003 10:29 PM
desperado_18_2000
May 19, 2002 11:35 AM
