79 4x4 front u bolt angle
Old Mar 3, 2019 | 04:04 PM
Lrrr-RulerOfOmicronP's Avatar
So my truck is a 68 f250 the previous owner swapped Dana 60s out of a 79 into. I do not like the angle of the front u bolts and started installing A ubolt flip kit but now steering is getting to be a pain due to the highboy frame... So is this normal? I do not have a dentside 4x4 to go look at.
Old Mar 3, 2019 | 05:54 PM
LONCO's Avatar
LONCO
I don’t have any experience with a highboy frame, but crossover steering, with a new arm on the pass side, might solve the problems. Plus it works ALOT better than stock. I don’t have pics right now, but can take some.
Old Mar 3, 2019 | 06:12 PM
I agree but I am spending a lot on the truck and trying to put some things off till later. Highboy frames have less Arch and I do not want to lift it more so I have to watch clearance when the front suspension is at full compression. I need a pitman arm that is almost flat to do crossover which I have not found yet.
So for now I just bent the spindle arm just enough to clear. Should work for a while. Thanks for the feedback!
Old Mar 3, 2019 | 09:19 PM
PA74F250's Avatar
PA74F250
Top plates were for the d44 the truck originally had. That axle doesn’t know if it’s under a highboy or a 79.
Old Mar 4, 2019 | 12:15 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I think a D60 steering arm spacer block can be sourced easy enough? Did you notch your axle webbing or drill a hole for the inboard u bolt? I can't quite see in the pic. Nice looking frame boxing and cross member fab work. As you now see with the shackle flip comes other clearance issues.
Old Mar 4, 2019 | 10:16 AM
Thanks for the feedback back guys.
Makes sense that the leaf spring upper plates were for the 68. I assumed the PO swapped them because he swapped the lower u bolt adapters.
I looked at spacer but they were not to cheap.
I think I am going to spring for crossover. I am working on installing a track bar and really should have they steering to make sure I get them parallel. I can buy everything for a couple hundred. It might get interesting since I do not have much room and don't want more lift. Truck is suppose to have 2" but it may just be at stock height.
Drivability is a big concern for me so I am going to have to get a sway bar stuffed in there too...
I have had to hack the crap out of the frame for a motor swap so I am trying to make sure it is beefed up to be as strong if not stronger than original.
Old Mar 4, 2019 | 01:42 PM
mark a.'s Avatar
mark a.
As far as the U bolts being at an angle, that's the way they are, nothing wrong with it. All of them, even the 44 use the same plates and are at a angle just like yours.
Old Mar 4, 2019 | 02:03 PM
Thanks for verifying!
BIGTRUCKBIGRV
Aug 16, 2017 01:35 PM
Morgan Whitman
Mar 24, 2017 05:21 PM
60'_f100
46
Mar 23, 2015 09:36 PM
husker77
Oct 16, 2012 05:09 PM
Ronzi
Offroad & 4x4
Sep 9, 2009 12:16 PM
