Door lock plastic part
Old Mar 3, 2019 | 07:58 AM
Motate455's Avatar
Motate455
77 f250. Replacing iginition and door locks started removing the driver door lock and there is a plastic piece that connects the lock to a rod that actuated the lock.
Being 42 years old it broke...it’s the part that pushes the rough the hole in the arm to keep it connected.
Anyone sell these? Or have a hack to make it work? Is there a tool I should use to prevent breaking the passenger one?
thanks
Old Mar 3, 2019 | 08:30 AM
alans77crew's Avatar
alans77crew
I think you can still get them from ford, It's been a couple years since I did but they still had them.
Old Mar 3, 2019 | 08:32 AM
84espy's Avatar
84espy
Go to the local yards and start checking out later model Ford CARS and trucks. These are pretty universal. They can be re-used. Just take care when removing them. They pop out with a little tension applied.
Old Mar 3, 2019 | 10:25 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Looks like this? Most auto parts stores carry it in the "help" section. https://www.oreillyauto.com/detail/b/dorman-help--4422/paint---body-repair-16614/body---trim-16771/door---window-16798/door-lock-clip-13243/ce7873f88812/dorman-help-door-lock-rod-clips/75451/4529615?q=ford+truck+door+rod+clip&pos=0
All clips... https://www.oreillyauto.com/search?q...+door+rod+clip
25 per package https://www.clipsandfasteners.com/Fo...e-p/a15675.htm
or https://www.clipsandfasteners.com/Do...d-p/a17122.htm pretty sure it is the yellow one. Also same clip for tailgate handle to latch rods.
File Type: pdf
Old Mar 3, 2019 | 11:19 AM
HoustonDave's Avatar
HoustonDave
Easily available at an auto parts store in the Help section. As an emergency fix, you can wrap a twist tie around the rod and around the lever arm, will hold it for a few years while you find a replacement.
Old Mar 3, 2019 | 01:28 PM
Motate455's Avatar
Motate455
Found them at napa. Thanks!
Old Mar 3, 2019 | 02:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Anyone sell these?
Same as LTD/Crown Vic/Grand Marquis/Town Car and etc Passenger Cars. Available from auto parts stores in the "help" section.
Old Mar 3, 2019 | 04:54 PM
lafermedavid's Avatar
lafermedavid
AMK out of Winchester Va,carries all door hardware,For Fords,,,,,,as well as other components hardware ,,,,,,,,,all their hardware is top notch heavy duty
Old Mar 5, 2019 | 03:29 PM
yankeerebel's Avatar
yankeerebel
I had the NAPA variety in my tailgate handle and they would pop out of the mounting holes periodically.
i just installed new ones from Dennis Carpenter this weekend. They were much more substantial than the Napa ones and seemed more secure in the holes. Time will tell how they hold up.
Old Mar 5, 2019 | 03:32 PM
Motate455's Avatar
Motate455
Thanks for that comment. I may order some from Dennis also
mgmoore7
Jul 3, 2011 11:27 AM
low 66
May 16, 2011 05:26 AM
ford4life69
Apr 5, 2010 10:37 AM
Ford1978F-150Ford
13
Nov 4, 2009 03:57 PM
Julies Cool F1
Aug 24, 2009 05:05 AM
