Rusty engine block
Old Mar 3, 2019 | 08:43 PM
ForeverFixing's Avatar
ForeverFixing
Wow, I had not noticed. I'll have to look now. Still better than my 2005 6.0 was. It was always covered in oil from one place or another. I love the new 6.7 rust or not.
Old Mar 3, 2019 | 09:57 PM
logear's Avatar
logear
That's not rust, that's a patina. Some hotrodders spend big bucks for that look.
Old Mar 3, 2019 | 11:59 PM
Louisville Joe's Avatar
Louisville Joe
This is a Ford thing. Other makes still paint their iron blocks. Most companies don't paint aluminum components though.
Old Mar 4, 2019 | 06:09 AM
FractureCritical's Avatar
FractureCritical
Originally Posted by GABAR
Ever heard of surface rust?
Very common and not unusual.
The same thing will happen to various items under your truck and this is no different than the brake rotors rusting after they have been exposed to water.
difference is that you can’t paint rotors and they only rust when you don’t use them. The lack of paint is BS, and this is coming from a guy who had a driveshaft explode under his truck due to corrosion loss.
When you’re pumping out one million trucks a year, the cost to coat the metal is pennies on a per unit basis. Anyone who says different just isn’t right. Sorry. The real problem is that the bean counters aren’t stupid. You don’t need an MBA to figure out cutting $5 from a truck you make a million of every year gets you $5M in windfall profit.
Old Mar 4, 2019 | 08:01 AM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by pruav
It is called patina. It adds value.
Joke in the car collecting hobby.
What is the difference between rust and patina?
$50,000
Old Mar 6, 2019 | 08:10 PM
GABAR's Avatar
GABAR
Very few manufacturers are painting the engine block or any external parts that are connected to an engine because a lot of the parts are aluminum. This surface rust is not something that`s new to Ford or any other manufacturer.
With that being said, it`s quite amusing to me that people complain about this on an expensive vehicle but don`t complain about it on an inexpensive vehicle. Cast iron is cast iron and regardless if it`s painted or not, especially in the northeast, that paint will wear off and the surface rust will appear.
Old Mar 6, 2019 | 08:13 PM
GABAR's Avatar
GABAR
How many iron blocks are still being used between all the makes.......that is the question.
Old Mar 6, 2019 | 08:16 PM
GABAR's Avatar
GABAR
Originally Posted by 09FX-4
I'm pretty sure my Cummins 6.7 had a painted block, as I never noticed it being this rusty. It's the first thing I noticed when I put the truck on my lift to check it out.
So you`re saying that your Cummins block was rusty though..... right?
I guess that paint didn`t hold up to well did it. lol
Old Mar 7, 2019 | 08:59 AM
redford's Avatar
redford
The standard automatic surface oiling system (leaks) keeps the rust off of the block on the Cummins.
khadma
Jul 4, 2017 07:56 PM
HVACTOM
Mar 20, 2015 05:28 PM
PRyan1983
Jun 26, 2003 10:56 AM
trinogt
Sep 6, 2002 08:13 AM
