Most reliable fuel pump for an inline 6 300?
Old Mar 2, 2019 | 05:33 PM
1984oldn’slow's Avatar
1984oldn’slow
My external fuel pump that is mounted on the inner frame rail went bad today so I have a cheap eBay fuel pump that I had as a spare mounted right now. I want to mount the new fuel pump on the outside of the frame rail. I was wondering what externally mounted fuel pump would be the most reliable, so that I won’t have to worry about it failing for a while. Thanks, Colby
Old Mar 2, 2019 | 05:39 PM
Franklin2's Avatar
Franklin2
Most reliable will be the mechanical style that goes on the engine. Any reason why you are not using that?
Old Mar 2, 2019 | 05:46 PM
1984oldn’slow
no,it came with an electric one mounted by the gas tank installed by the previous owner. I will look into a Manuel one. Are certain brands better than other? Because I know a lot of the new parts you get from the parts store don’t always last that long.
Old Mar 2, 2019 | 05:48 PM
Franklin2's Avatar
Franklin2
I would pick the store you are most comfortable with and use their pump. I see Autozone sells a Delphi pump.
Old Mar 2, 2019 | 05:58 PM
1984oldn’slow
I’m thinking of either a Delphi or a Napa auto pump. Are Delphi pumps know to last a while?
Old Mar 2, 2019 | 06:12 PM
FuzzFace2's Avatar
FuzzFace2
For my 81 300 six I got what ever pump Auto Zone had.
Cant remember now who made it or if they had to order it but been working so far to move it around wile building it.
Dave ----
Old Mar 2, 2019 | 08:58 PM
matthewq4b's Avatar
matthewq4b
Back in the day Airtex and Carter were the OEM suppliers. Given the choice now I would source out an Airtex as it is identical to the OEM pattern in terms of construction and design.
https://www.rockauto.com/en/catalog/ford,1983,f-150,4.9l+300cid+l6,1121353,fuel+&+air,fuel+pump,62 56
Old Mar 2, 2019 | 09:09 PM
Tedster9's Avatar
Tedster9
It is important to measure fuel pump pressure output, the parts house replacement pumps are all over the place. A mechanic's vacuum gauge (which you should have already) will measure mechanical pump pressure output as well as engine & carb diagnostics.
fixnair
Dec 17, 2012 09:15 PM
lifted77f250
Jul 26, 2010 06:59 AM
Edmelott
Jul 8, 2010 01:29 AM
mechelement
17
Feb 15, 2009 04:25 PM
87ford
16
Oct 24, 2006 01:50 PM
