Sponsored by: Real Truck
'16 multi-function switch
Old Feb 28, 2019 | 11:22 AM
Ron94150's Avatar
Ron94150
So, my very occasional phantom wipe on start up has turned into full time 30 second delay that want turn off. My question is, what have you guys used for replacement. As common of a problem as this is with this generation truck, is it really smart to put a motorcraft back in it? What replacement brands have y'all had go luck with?
Old Feb 28, 2019 | 10:50 PM
Hamfist's Avatar
Hamfist
I need to replace mine as well. Seems like it's not too hard to do and the motorcraft part is only $30-35. Even if I have to replace it again in 2 or 3 years it's really not a big deal.
Old Mar 1, 2019 | 11:16 AM
IDI Diesel's Avatar
IDI Diesel
Not sure if this is what your talking about butttt on my '15 there is a "COURTESY WIPE" that can be toggled on/off with the steering wheel controls.
Old Mar 1, 2019 | 11:20 AM
Ron94150's Avatar
Ron94150
Nope, not the courtesy wipe. I have it turned off. This is just the wiper switch not turning all the way off. When it's in the off position, it still performs the slowest delay wipe.
Old Mar 1, 2019 | 11:30 AM
mikereidjr's Avatar
mikereidjr
You need a 5.5mm socket to take the steering column apart, I didn't know they made a special socket for that, but they do.
Old Mar 1, 2019 | 12:21 PM
Hamfist's Avatar
Hamfist
The multi-malfunction switch is notorious for failing on these trucks and the most common issue is what I and apparently Ron have, where the wipers will not turn all the way off. A couple weeks ago I was at the dealer having the transmission service done on my truck and there were 2 guys in the waiting room both having their switches replaced because their wipers were also doing this.
Old Mar 1, 2019 | 01:18 PM
redford's Avatar
redford
FTE Leadership Emeritus
Not just these trucks. My previous 1995 F150 also had a multifunction switch that needed replacing.
I kept putting up with it acting odd, but when I was unable to use my wipers unless my lights were in high beam I knew I had pushed it a little too far.
Old Mar 1, 2019 | 07:00 PM
Djosbun's Avatar
Djosbun
A 5.5mm socket wasn’t made specifically for this, as it is used in a handful of late model cars. I’ve used mine a few times in the last 3-4 years.
— Dave
Old Mar 2, 2019 | 09:40 AM
joeycyph56's Avatar
joeycyph56
man i thought it was just my rig doing the phantom wipe. odd thing is it went away now which kinda scares me now as i dont know if it just will stop working all of a sudden. guess its time to replace. i was just going to order one from rock auto and i think the manufacturer is dorman.
75highboy390
29
Jul 14, 2013 10:27 PM
clemjr
Mar 27, 2012 06:45 PM
atillett
Dec 16, 2007 11:10 AM
hofmeyer
Sep 6, 2006 07:59 PM
D Ray
Aug 19, 2002 12:50 PM
